2x r33 mspec front bars, average conditions, one has a crack on it somewhere that could be repaired easily ( not obvious) and the other ones fairly decent condition... seeing as someone is selling a perfect one for $250 i will accept offers of what... $80 firm for the one with the crack and $120 for the one without crack.
I also have 4x17" work rims, one damaged. Paint stripped at the moment, and ready for painting. They come with fairly decent rubber 255 on back 245 or 235 on the front.. this rubber is falken and its pretty awsome stuff. studd pattern 4x114.3 and 5x114.3 ~$300 for the set.
Items are located in canberra, and i can post interstate @ buyers expense.
Dayne
Dayne
hey man, can you please post pictures? very interested...
thank you
hey mate, what are you after pictures of?
i just took pictures for another interested buyer, so i'll post them up for you.
Bar #1 ~ has a few minor gutter rash marks, could be removed easy. Has been sand blasted.
http://i8.photobucket.com/albums/a30/lo_r33/IMGP0243.jpg
http://i8.photobucket.com/albums/a30/lo_r33/IMGP0242.jpg
http://i8.photobucket.com/albums/a30/lo_r33/IMGP0241.jpg
Bar#2 ~ has a small crack, 3/4 of the crack has been plastic welded, has next to none gutter rash marks, and could be fixed for next to nothing. Has been sand blasted.
http://i8.photobucket.com/albums/a30/lo_r33/IMGP0245.jpg
http://i8.photobucket.com/albums/a30/lo_r33/IMGP0246.jpg
http://i8.photobucket.com/albums/a30/lo_r33/IMGP0247.jpg
http://i8.photobucket.com/albums/a30/lo_r33/IMGP0244.jpg
Cheers
Dayne
One rim is bent. The rubber on them is fkn expensive stuff! These rims when i got a qoute to repair the guy said they retailed at about $1000 each!
http://i8.photobucket.com/albums/a30/lo_r33/IMGP0250.jpg
http://i8.photobucket.com/albums/a30/lo_r33/IMGP0248.jpg
http://i8.photobucket.com/albums/a30/lo_r33/IMGP0249.jpg
and this last one is the f**ked rim.
http://i8.photobucket.com/albums/a30/lo_r33/IMGP0251.jpg
Bump!!! NEEDS TO SELL ASAP!
Dayne
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
