and whats wrong with that!!!  hmmm!!!!!!!!
You'll need at least one passenger to spot the answer to questions and write them down, or will be in for a VERRRRRRRRY long day otherwise.
Fatz tried it a few years ago running with his dog as navigator.
Let's just say he didn't get too many questions right.....
  • Replies 149
There's no real "cruising" involved- as with other years, cars will leave close together (approx. 1 min apart) and meet up at the end.
You'll see people as you're driving around but it won't be like a normal cruise/procession.
I promise it will still be good fun though!
If anyone can't find a passenger to run with, it may be better to PM me and we can give details of where we'll be meeting up at the end (provided you don't share this info with anyone actually doing the observation cruise!).
ey guyz..im a new member to the forum but i dun exactly know whether im considered a official SAU member or not i drive a skyline n all but do i need the member card in order to b considered a official member to attend the xmas party?
We should all be at the destination by 1.
Then it's a barbie lunch, running through the answers to the questions and maybe a game of soccer if anyone's feeling energetic.
Should finish up around 4 but everyone free to leave earlier or later.
The cruise will end approx. 2 hours from Sydney (and you'll be south west/south for most of the day).
Hope this helps?
Kel
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
