Hey y'all
I've tried searching the classifieds but really couldn't find anything.
Just wondering how much $ i should put on my Nismo R34 front bar? i've bought another front bar, i need to sell mine but just don't want to give it away for what might be too low a price.
cheers,
chinny
https://www.sau.com.au/forums/topic/95331-r34-nismo-altia-front-bar/
ah... the aero one. like i said. Nismo (or technically, Altia) front bar. As in the pic in my sig.
No cracks, but a few scuffs i think on one of the corners, i'll have to go over thoroughly and check it.
So i'd say very good, with a few scuffs (thank you shipping)
yeah, the lovely ppl at Powerplay hooked me up with a VERY nice front bar :P (thanks tosh/jo)
no less than $600 u reckon tosh? oh well... you deal with these things all the time so your word is more than enough for me.
I have someone who was already interested in this bar from a little while back, but now that i'm ready to sell, we weren't sure what to ask/pay for it. but if it falls through, i got ur pm's guys :blink:
cheers
chinny
just to let u guys know what's happening, i pm'd the first guy interested, to see what he thinks... i'll let you guys know how that goes.
cheers.
p.s. i'll fix the front bar link too soon.
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
