Crusin around on da web and found this....The sequel 2 the original F&F is being called 2 Fast 2 Furious (highly original title!). Here is a pic of the mian characters from the movie and their cars. From what i can tell the two most indisdiguishable R the s2000 (which looks like a Barbie car) and the Rx7. The R34 isn't particularly inspiring but the Supra looks cool....thoughts????
https://www.sau.com.au/forums/topic/9545-2-fast-2-furious/
  • Replies 41
Bullcrapola
The RX7 is the best.
Maybe its a GTT (which is still a mighty fine car)..I remember another shot which had two "R34" lookalikes, in the same paint as that Skyline...but they do look a little flat on the sides for a R
https://www.sau.com.au/forums/topic/9545-2-fast-2-furious/#findComment-144949
i don't really care about the rice .. sometimes it looks good sometimes it doesn't ... i just wanna see how the cars are portrayed in the movie ... like in the first one .. u'd think that all u had to do was buy one of the shop and u have a 10 second car ... and it also seemed like any bogan off the street could afford one ...
https://www.sau.com.au/forums/topic/9545-2-fast-2-furious/#findComment-145155
yeah, that movie had so much wank factor it wasn't funny. With the laptop and all the flashing rice to change the parameters.
And kids basically just hanging around doing nothing driving $50k+ cars.. sounds like drug dealing to me behind the scenes - we can't have that in a movie :D
https://www.sau.com.au/forums/topic/9545-2-fast-2-furious/#findComment-145616
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
