  • Replies 64
Posted Images
^^ kool man just keep an eye out on the forum and we can meet up next cruise
for the other guys, yea i work at tcf international, been a runner for like over 9 months now, sux im waitin for them 2 hire some1 else 2 do my job
yea that red rx7 fc in ags is nice also
deanzzz what car do u drive?
and that gtr on botany road is mad!!!
good thing about my job? soo many hot chiks at different places
that is exactly the car im talking about =D
i love that thing so much
got any details on it? :P
yeh as a matter a fact i do
what happen was they where doing some minor work on the car and he forgot to take all the rags out of the intake and blow the turbos. so it got n1's some engine work pfc and a very big brake upgrade. it has a set of cyber head light covers and bbs rims. has enough power to smoke all four
the work was done by japboyz, gave them a hand one night when the where doing it.
Edited by mr 32
Tim, hi its adrian, i stopped by cronulla, couple of friday nights ago, when you where with the yellow 33 and the white and black r32, you were saying how much you loved the gtr'z, just wondering if you guys are cruising one night,
Hi Mate, so far got nothing planned i wouldnt mind going for one this friday night, if anyone is up for it ??? :P
oi mitch come 2 my sisters formal.. need a black 33 to attend.. If my friend cant make it, u will be takin one of the chicks to formal, thats if u can make it.. Anyways will let u know more details on msn anwyays..
hmm 8th dec is thursday. Formal starts 6.30pm. so leave around 5.45 or 5.30.. hmm will post up details tonight, once i speak 2 my sister.. I know its around san souci(spellin) area..
Cheers guys...
Yeah ill prob go, got more details??
You comming to the formal run on the 8th... ( i tihnk we need to start charging :lol: )
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
