I have driven my s13 with a rb26dett conversion for a while now and the compression has started to go down due to high pressure from the garret gt35/40.
At this time writing, I am planning a rebuild so I can use the full potensial of the turbo and possibly make 680-700 flywheel hp.
It would have been great if you could help me with the engine spec.
My plans so far:
boring and honing of block
polished and balanced crank
hks forged pistons 1mm oversize
nismo n1 oilpump
nismo rod and main bearings
jun headstuds
hks 1,6mm headgasket
tomei rod bolts
tomei oil gallery orifice
I also plan to shotpeen my original rods and maybe get them polished afterwords.
Is there anyone who can tell me how this is done?
Anyone who does this for a reasoable amount of money?
Do I need anything else to make the bottom end reliable?
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/
boring and honing of block DECK THE BLOCK AND THE HEAD ALSO (to help the metal head gasket seal)
polished and balanced crank IS YOUR RB CRANK R32 IF SO YOU WILL NEED TO FIX THE OIL PUMP DRIVE JUN CRANK COLLAR
hks forged pistons 1mm oversize or CP MAKE GREAT PISTONS USA
nismo n1 oilpump FOR THE BHP I WOULD CONCIDER A JUN OIL PUMP(especially if you plan to rev it hard)
nismo rod and main bearings NISMO THE BEST
jun headstuds
hks 1,6mm headgasket YOU ARE NOT CONCERN WITH RESPONCE BY RUNNING A THINK HG YES?
tomei rod bolts I WOULD BUY RODS ie PAUTER IN USA OR TOMEI/HKS ALL GOOD
YOU HAVE NOT MENTIONED THE HEAD SPECS what did you plan to run as bhp is basically pistons up?
pete
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/#findComment-1731458
jun headstuds
pete
thanks for the comments Pete!
Yes, i will deck head and block aswell.
It,s a r33 engine so dont need to do any changes with the oil pump drive?
I see that the jun pump is ALOT more expensive than nismo,
will try to keep i under 7800rpm so I hope the nismo is good enough.
for the headgasket, is 1,2 mm thick enough for my application?
Isnt the original shotpeened rods good for around 700bhp?
The head has been profesionally ported,gasfloved, and rebuildt.(also the combutioncamber)
any more help would be great!
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/#findComment-1733604
Yeah 1.2m head gasket will be fine
The std rods will take alot but 700bhp would be the limit and after such an $$ rebuild it would be a shame to lose a leg out the side(i got my pauter forged rods for $1500AUD deliveried)
The N1 oil pump is not NISMO and is the same as std, bare a stronger pressure relief spring and if your not going over 8000rpm will be fine.
What cams are you running and have you bought adjustable cam wheels for them?
What will the primary purpose of the car be?
pete
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/#findComment-1733957
ditch the jun headstuds and rod bolts and fit some arp bits.
http://www.paceparts.com/index.asp?PageAct...S&Category=7740 sells the head studs at a very reasonable price but you will proly have to look around for the arp rod bolts (tomei use arp bolts).
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/#findComment-1739752
Thanks for the good info guys!!
I will use arp bolts now.
The cams I am using is the tomei 260 type b with adj pulleys.
What are the recomended adjustments of the pulleys?
Or do I have to adjust them on a dyno?
The car will be used as a street car mainly.
And it will also be used at tracks and maybe some 1/4 miles :P
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/#findComment-1743005
What are the recomended adjustments of the Tomei pulleys?
Do you adjust them on a dyno?
Or when the engine is out?
dyno is the best place as you can see the direct effect of any changes and every motor is a little different. But i have found a little advance on inlet gives better and earlier low down power and some motors responced to a little exhaust advance as well. Best to test all changes on the dyno and you need to remember to reset timing when adjusting the exhaust timing.
pete
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/#findComment-1751048
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
