I have driven my s13 with a rb26dett conversion for a while now and the compression has started to go down due to high pressure from the garret gt35/40.
At this time writing, I am planning a rebuild so I can use the full potensial of the turbo and possibly make 680-700 flywheel hp.
It would have been great if you could help me with the engine spec.
My plans so far:
boring and honing of block
polished and balanced crank
hks forged pistons 1mm oversize
nismo n1 oilpump
nismo rod and main bearings
jun headstuds
hks 1,6mm headgasket
tomei rod bolts
tomei oil gallery orifice
I also plan to shotpeen my original rods and maybe get them polished afterwords.
Is there anyone who can tell me how this is done?
Anyone who does this for a reasoable amount of money?
Do I need anything else to make the bottom end reliable?
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/
boring and honing of block DECK THE BLOCK AND THE HEAD ALSO (to help the metal head gasket seal)
polished and balanced crank IS YOUR RB CRANK R32 IF SO YOU WILL NEED TO FIX THE OIL PUMP DRIVE JUN CRANK COLLAR
hks forged pistons 1mm oversize or CP MAKE GREAT PISTONS USA
nismo n1 oilpump FOR THE BHP I WOULD CONCIDER A JUN OIL PUMP(especially if you plan to rev it hard)
nismo rod and main bearings NISMO THE BEST
jun headstuds
hks 1,6mm headgasket YOU ARE NOT CONCERN WITH RESPONCE BY RUNNING A THINK HG YES?
tomei rod bolts I WOULD BUY RODS ie PAUTER IN USA OR TOMEI/HKS ALL GOOD
YOU HAVE NOT MENTIONED THE HEAD SPECS what did you plan to run as bhp is basically pistons up?
pete
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/#findComment-1731458
jun headstuds
pete
thanks for the comments Pete!
Yes, i will deck head and block aswell.
It,s a r33 engine so dont need to do any changes with the oil pump drive?
I see that the jun pump is ALOT more expensive than nismo,
will try to keep i under 7800rpm so I hope the nismo is good enough.
for the headgasket, is 1,2 mm thick enough for my application?
Isnt the original shotpeened rods good for around 700bhp?
The head has been profesionally ported,gasfloved, and rebuildt.(also the combutioncamber)
any more help would be great!
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/#findComment-1733604
Yeah 1.2m head gasket will be fine
The std rods will take alot but 700bhp would be the limit and after such an $$ rebuild it would be a shame to lose a leg out the side(i got my pauter forged rods for $1500AUD deliveried)
The N1 oil pump is not NISMO and is the same as std, bare a stronger pressure relief spring and if your not going over 8000rpm will be fine.
What cams are you running and have you bought adjustable cam wheels for them?
What will the primary purpose of the car be?
pete
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/#findComment-1733957
ditch the jun headstuds and rod bolts and fit some arp bits.
http://www.paceparts.com/index.asp?PageAct...S&Category=7740 sells the head studs at a very reasonable price but you will proly have to look around for the arp rod bolts (tomei use arp bolts).
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/#findComment-1739752
Thanks for the good info guys!!
I will use arp bolts now.
The cams I am using is the tomei 260 type b with adj pulleys.
What are the recomended adjustments of the pulleys?
Or do I have to adjust them on a dyno?
The car will be used as a street car mainly.
And it will also be used at tracks and maybe some 1/4 miles :P
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/#findComment-1743005
What are the recomended adjustments of the Tomei pulleys?
Do you adjust them on a dyno?
Or when the engine is out?
dyno is the best place as you can see the direct effect of any changes and every motor is a little different. But i have found a little advance on inlet gives better and earlier low down power and some motors responced to a little exhaust advance as well. Best to test all changes on the dyno and you need to remember to reset timing when adjusting the exhaust timing.
pete
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/#findComment-1751048
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
