piss off you The land of goat sphincter rings felafel roll haha
yeah john, it was sold out 2 days after they came on sale back in september, i managed to get some tickets today but had to pay abit extra...
but my mate won pokies tonight and shouted me the ticket so i got it for free!
cheering!
cheering!
im no The land of goat sphincter rings pide u kabab
yeh u can buy of ebay for 200% the cost
just wanted to see which skyliners are going to field day on 1st Jan at the domain
I got my tickets today, cant wait!
Barns
Yep yep.. Im going. Cant wait!!!
Hmmm in past years I havent noticed many arabs.. There is a few wherever you go, but next to none at Field Day B)
lol johnny you wish i was arab.
your a turk wana be cypriot wana be greek! lol
should be good on the day, they've got a good line up
ROGER SANCHEZ DERRICK CARTER BOB SINCLAR KRAFTY KUTS + TC IZLAM STEREO MCs LIVE EVIL NINE TIEFSCHWARZ STANTON WARRIORS (DOMINIC B) THE GLIMMERS SOUL OF MAN INFUSION SWIRL PEOPLE (DJ SET) DJ FORMAT
Kid Kenobi / MC Shureshock - Ajax Jonathan Wall - Ben Drayton - John Devecchis - Mark Murphy - Funktrust / Will Styles & Learned Hand - Dave Slade - The Bang Gang DJs Feat Gus Da Hoodratt, Jaime Doom, DJ Damage & Dangerous Dan - James Taylor + more
i have never seen so many hot girls in such little clothing in one place in my life
its definately one of the best days of the year
i hear that mate.
this is the second year straight iv missed.
enjoy guys and girls
