thedriver Posted November 22, 2005 Share Posted November 22, 2005 Does anyone know if the Stagea (S2) comes with a factory immobiliser? If so, how many points does it work on? I need to know if I have to go a buy an immobiliser. Link to comment https://www.sau.com.au/forums/topic/95941-immobiliser/ Share on other sites More sharing options...
AlexCim Posted November 22, 2005 Share Posted November 22, 2005 It doesnt. At least, mine didnt....but that doesnt say much Link to comment https://www.sau.com.au/forums/topic/95941-immobiliser/#findComment-1737051 Share on other sites More sharing options...
Terminal Posted November 22, 2005 Share Posted November 22, 2005 Also yours is a series 1, he was asking about series 2, hehe Link to comment https://www.sau.com.au/forums/topic/95941-immobiliser/#findComment-1737073 Share on other sites More sharing options...
AlexCim Posted November 22, 2005 Share Posted November 22, 2005 Touche my friend, touche! Link to comment https://www.sau.com.au/forums/topic/95941-immobiliser/#findComment-1737148 Share on other sites More sharing options...
thedriver Posted November 24, 2005 Author Share Posted November 24, 2005 Also yours is a series 1, he was asking about series 2, hehe <{POST_SNAPBACK}> Anyone with an S2 know??? Link to comment https://www.sau.com.au/forums/topic/95941-immobiliser/#findComment-1740328 Share on other sites More sharing options...
chook Posted November 24, 2005 Share Posted November 24, 2005 mine doesnt, and im pretty sure none did, ive just installed a 'proximity' 2 point immobiliser, auto arm and disarm, still get to keep and use the factory keyless remote. Link to comment https://www.sau.com.au/forums/topic/95941-immobiliser/#findComment-1742242 Share on other sites More sharing options...
mcnamg Posted November 24, 2005 Share Posted November 24, 2005 had a quick squizz at the spec sheets i have and cant see an immobiliser Link to comment https://www.sau.com.au/forums/topic/95941-immobiliser/#findComment-1742409 Share on other sites More sharing options...
thedriver Posted November 24, 2005 Author Share Posted November 24, 2005 (edited) Anyone had any experience with the Powerlock immobiliser??? Following extracted from the CarSafe website (just in case you are looking for an immobiliser): STANDARD FEATURESAll Australian Standards approved immobiliser systems include: Automatic immobilisation within 40 seconds of ignition switch-off Two independent points of immobilisation Connections enclosed in security housing All black security wiring Flashing dashboard LED when system is armed Secure owner PIN override. Engine immobilisers fitted under the Immobilise Now! Program do not include an alarm as a standard, but some models may be integrated with an alarm and other optional features. Most insures will require an Australian Standards approved immobiliser for Comprehensive cover. Edited November 24, 2005 by thedriver Link to comment https://www.sau.com.au/forums/topic/95941-immobiliser/#findComment-1742626 Share on other sites More sharing options...
Red Sky II Posted November 24, 2005 Share Posted November 24, 2005 Not sure if it is an immobiliser or not but I did some testing of the factory remote. If it is "armed" (closed with remote button) and you open the door with the key itself, as soon as you put the key in the ignition, the horn sounds and the lights flash. Must admit didn't try starting it though. There are some other things that trigger off the horn as well when I was playing around but can't think of them just now. Perhaps just try locking doors with remote, opening door with the key and try starting the car (whilst ignoring the horn going off is yours does that). If it starts then no immobiliser but if it doesn't then perhaps it has one. Would be interested to know the results. Link to comment https://www.sau.com.au/forums/topic/95941-immobiliser/#findComment-1742756 Share on other sites More sharing options...
thedriver Posted November 24, 2005 Author Share Posted November 24, 2005 Will try that tonight. Good thinking ninety nine! Link to comment https://www.sau.com.au/forums/topic/95941-immobiliser/#findComment-1743126 Share on other sites More sharing options...
Terminal Posted November 25, 2005 Share Posted November 25, 2005 if i kick my bumper the alarm goes off, dunno if that's standard Link to comment https://www.sau.com.au/forums/topic/95941-immobiliser/#findComment-1743435 Share on other sites More sharing options...
thedriver Posted November 26, 2005 Author Share Posted November 26, 2005 ... There are some other things that trigger off the horn as well when I was playing around but can't think of them just now.Perhaps just try locking doors with remote, opening door with the key and try starting the car (whilst ignoring the horn going off is yours does that). If it starts then no immobiliser but if it doesn't then perhaps it has one. Would be interested to know the results. <{POST_SNAPBACK}> No luck. Mine did no such thing and the engine wasn't immobilised. Sounds like you have either a factory fitted alarm or an aftermarket one. Link to comment https://www.sau.com.au/forums/topic/95941-immobiliser/#findComment-1746164 Share on other sites More sharing options...
Red Sky II Posted November 26, 2005 Share Posted November 26, 2005 No luck. Mine did no such thing and the engine wasn't immobilised. Sounds like you have either a factory fitted alarm or an aftermarket one. <{POST_SNAPBACK}> You have me curious now - must go and check whether the car start whilst the horn is sounding, etc. Must be factory or using th factory key remote as that is the only one I have. Link to comment https://www.sau.com.au/forums/topic/95941-immobiliser/#findComment-1746813 Share on other sites More sharing options...
thedriver Posted November 27, 2005 Author Share Posted November 27, 2005 You have me curious now - must go and check whether the car start whilst the horn is sounding, etc. Must be factory or using th factory key remote as that is the only one I have. <{POST_SNAPBACK}> What happened? Link to comment https://www.sau.com.au/forums/topic/95941-immobiliser/#findComment-1748065 Share on other sites More sharing options...
