Everyone seems to say that the turbo is a mismatched turbo at the best of times.  Quite laggy.  On an RB20 I imagine it would be even worse.
There are numerous turbos out there that would be better.
just came accross one at the right price, what turbo would be a better option
also did a search and didnt find alot relating to rb20's using this turbo.
nothing is a "good price" if its worse than what you currently have or gives bad results and may end up costing more. a more suitable turbo would be a hks 2530, an rb25 stock unit or a hiflowed unit.
whats your power target? theres a massive thread on rb20 top rwkw club in the forced induction section, should be easy to find
im not entirely up with all this 28 76r stuff and all the new garrett model numbers and stuff
how ever i know a bloke with a rb20 running a bb Gt25 440hp .7 comp cover .86 ex turbo is extremely laggy.. not the best combo at all best hp figure was 320rwhp turbo doesnt generaly hit full boost untill about 4500rpm or more.. and that power was made running big boost 25psi roughly but yer the turbo would be suited more for a rb25 but even than.. i still wouldnt run one as there are much better options out there
Wazz
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
