I think this symmetrical thing is trying to show that subies have very good balance. GTR's 4WD lets the rear wheels kick out before the front wheels come into action. Takes a little getting use to at first, but it's quicker once you get the hang of it.
The symmetry they refer to lyes in the drive split between the front at rear. For instance the late Ford TX3 4WD's had more drive to the rear than the front, making it a pretty fun car to drive (i think it was 35/65). Where as the WRX's have a 50/50 split, and while this is symmetrical and balanced, its also boring. As many RWD owners will tell you "Symmetry creates understeer"
Attessa is a brilliant system, it has to be said, keeps the car heaps of fun to drive, whilst having the advantage of 4wd when you need it. Think of it as a variable split which only delivers front drive when theres traction loss.
Red17
The problem with attessa is that it is relatively complex and expensive. It is a fully electronic system than can vary the split from 50/50 to all RWD. Other lesser systems are totally mechanical 50/50.
Clearly attessa is the best and who says that owning a Skyline means compromising on engineering?
T.
Red17 has got it. 50/50 split will cause understeer simular to a front wheel drive car. And we all know that front wheel drive cars are for people who can't drive LOL....... ie. the WRX driver :lol: :lol:
I read somewhere (I think it was Autospeed), that the reason they set up cars to understeer is because of the dummy factor !!!
The comon driver doesn't know how to control a car in oversteer, but any dummy can control and get out of a situation that has understeer - you just take you foot off the go peddal.
And taking your foot off the go pedal is apparently a natural reaction for 90% of drivers when they loose control of a car.
The GTR's electronically controlled AWD driveline (ATTESSA) is brilliant - far more rewarding and technologically advanced than Subaru's AWD system. Torque split is biased 100% to the rear wheels until the rear tyres break traction , then the bias varies to a max of 50/50 front-to-rear gradually fowarding torque to the front wheels. This makes the GTR bloody fast on launches as initial slip at the rear tyres prevents the engine from bogging down through too much traction, and the front wheels provide wickedly quick drive for rapid acceleration.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
