no havent organised anything as yet. but will probably go check it out anyway. is there a cruise tomorrow? my clutch is playing up a bit as i just got the motor tuned properly on a dyno, now it slip[s in second like no tomorrow. dont wont to get stranded anywhere. will replace clutch before going on cruises in the future as i am just puttin around at the moment. any suggestions clutch wise?? im pretty sure mine is standard so a brass button heavy duty should keep me happy for a while. :)
Edited by HR-32
https://www.sau.com.au/forums/topic/96251-new-member/#findComment-1746677
no havent organised anything as yet. but will probably go check it out anyway. is there a cruise tomorrow? my clutch is playing up a bit as i just got the motor tuned properly on a dyno, now it slip[s in second like no tomorrow. dont wont to get stranded anywhere. will replace clutch before going on cruises in the future as i am just puttin around at the moment. any suggestions clutch wise?? im pretty sure mine is standard so a brass button heavy duty should keep me happy for a while. :angry:
i got the same problem, mine slips like crazy 2nd n upwards. started after the midnight cruise. im getting a heavy duty installed by my local mechanic, around $600, he put in a heavy duty on my old r33 gts 2 yrs ago an it was heaps good. i got prices at like other mechanics (ultra tune, midas, etc) n they all say clost to a grand. the only bad thing is ive had 2 wait 2 weeks cos he is busy, n now its getting done on thursday so i cant wait, cos i got a boost controller and i havent got a chance 2 use it yet haha
https://www.sau.com.au/forums/topic/96251-new-member/#findComment-1747302
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
