I took my BOV off today cause I was sure it was leaking, and you wouldn't believe what I found out...
The factory BOV is designed to leak !!!!
Yepp, it's designed to leak....
Have a look at the attached pic. If you blow into the return pipe (big pipe on the bottom lefthand side) it will blow through the BOV and out that little hole on the front. That means there is always a path to recuiculate a small amount of air even when the BOV is totally shut !!!
I don't know why....
Anyway, here is a quick "how too".
I got this idea from a bloke on SDU. The link is here http://forums.skylinesdownunder.co.nz/show...=&postid=191358
J
  • Replies 85
Posted Images
I found a wood screw that had a flat head that was about 1 1/2 inches long. It'll be hard to find one that fits good, but keep looking.
The important thing to do is to counter sink the hole a little in the BOV so when you screw the screw in it sits flat with the base of the BOV.
You can see it in this pic.
Put it back on the car and your all finished.
The car does feel more responsive when on boost. And there isn't that sound of recirculating air when your on boost as much.
The sound it makes has changed slightly. Before it was more of a ssssssshhhhhhhtttttt noise. But now is more of a pppppssssshhttt noise (if that makes sense !!).
It sound like it's holding the boost until you come off the throttle instead of passing air (LMAO :lol: ) when your foot is still down.
It can't be bad for it, have a look at any of the after market BOV and they don't have this little bleed hole, so what the hell
Have fun.
J
th hole is ther to recirculate a little air when off boost
its supposed to keep the turbo spinning faster so it spools up quicker
but if you want to block it all you need to do is put a thick peice of gasket paper over the hole and when you clamp the bov back down again it will be held in place and thats enought to block it properly
no screws required
Cool, good to see there's some sort of reason why it's there. It's a shame that sometime effects it pretty bad when running higher boost :wave:
Joe - that screw won't go anywhere, when you bolt the BOV back on it's hard up against the crossover pipe mounting point. No way it's coming out :)
I've been keeping an eye on the boost gauge today.
With lite throttle boost situations it seems to come on faster. Before if I was accelerating slowing and it gradually came on boost I found it would get to about 1-2psi, then drop back to 0 and then build up again. Not sure why, but that has now stopped.
I figure that hole would bleed at least 2-3psi of boost. I think the hole is a great idea if your running standard boost, but if you up the boost it'll bleed more.
I'll be leaving mine with it in. Can't hurt, plus the noise is fulsik now.... maaaateee... :lol: :lol:
Well it looks like someone else came up with the same idea a while ago!!
Have a look here;
http://www.thedodgegarage.com/turbo_bov_mod.html
But they did it slightly different so you could have it "fast open - like stock" or normal so it hold boost better.
Rev, I can't confirm any times or anything, and I'm not going to guess, but to me it feels more positive. Either way it's easy to reverse if need it be. OH, BTW - I did the thermo fan install yesterday. It does rev slightly faster now, nothing amazing, but there is a difference. It's so quiet now too, but when the fan turns on it sounds like a jet engine !!! I now like your idea about reducing rotational masses. :) :uh-huh:
J
Guest /\/\/\/\/\/\/\/\/\/\/\/\/
Hi, that was my original post on sdu
the boost doesn't actually leak thru that hole, when enough pressure goes throught that hole it opens the bov piston. and the boost escapes through there.
it is just a system nissan has put there to prevent overboosting
Originally posted by turbomad
I noticed that extra port doesn't actually go into the plumb back section of the BOV, it has it's own tunnel into the diaphram part, how does it circulate air?
If you've got the BOV sitting in your hand and you blow into the plumbback pipe, air will come out that small port, regardless if the valve is open or closed.
Jay95R33
thanks for the great post ... I found a spare factory BOV in the depths of my boot :P ... have also just found the HKS turbo timer measures boostD :D :D , just need to connect it ...
over the weekend I will try both BOV's (unmod &mod)and if I have any interesting figures I'll post it
Originally posted by Blackness
Jay95R33
Balckness - dude that would be great if you post up how it goes. And good find in your boot, all I found in my boot when I got the car was a dirty old ash tray from some brothel in japan :(
also found one thrashed jack with no handle, an ultra light spare tyre and tyre brace (read none) and a dirty Nike hat...:P
the spare BOV has a couple of scratches on the face plate, but I might get keen with some fine sand paper .....
Does the BOV have rubber grommet as a seal or is it a flush metal disk (the spring loaded part)....
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
