Hey everyone
Just some questions to see if any1 can help.
My car was recently dynoed at 175rwkw at 10psi. Its got a front mount, 3" from the turbo and some other stuff.
I was told that i shouldnt go any higher than 10psi because stuff could snap. The previous owner said he could run 14psi on a bleed valve.
What else can i do to get some more power? i was hoping to get around the 200rwkw with the boost controller but yet...
what else can i do to my car?
cheers
https://www.sau.com.au/forums/topic/96385-rwkw/
Yes but wen you do that you can hav problems
There is only so much you want to run
After that engine blow up will be around the corner and rwkw does not mean you have a good car t drive
Power with power band is wat you need
james
https://www.sau.com.au/forums/topic/96385-rwkw/#findComment-1747360
cant i increase the psi higher than 10psi?
not on the stock turbo. 10-12psi is where its making its max power without putting too much stress on it. Ive heard that running more than 12psi through the stock T3, wont achieve much of a power gain anyway. and that running anything higher than 14psi for extended periods will kill the exhaust wheel.
https://www.sau.com.au/forums/topic/96385-rwkw/#findComment-1747363
200 +RWKW.
Back in the early days of messing with the rb25's we found that anything over 12lbs wasn't a very good idea, as it places too much strain on the std bottom end hence doesn't promote longetivity.
We found using a high flowed std turbo using a front mount, full 3" exhaust , pfc, boost controller would run at just over 200 rkws but would then run in to issues with fuel pressure etc, so i would recomend using a good quality fuel pump and pressure reg at the least but injectors if you can afford it. When its all said and done you cant axpect to get much more out of a std bottom end and have durability and the ability to be a daily driver etc. Thats why the blokes that are deadly serious about racing etc use os gkn motors that have nearly indesructable bottom ends etc to run rediculous amount of boost.It's also the reason i have built a stout 3ltr motor using good quality internals that will comfortably handle more than 2bar of boost when required.
Regards,
SKYLINE...(Kym) B)
https://www.sau.com.au/forums/topic/96385-rwkw/#findComment-1747970
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
