hey all, i was just reading up on how some people suggest installing the AFM in the cooler piping, i did a search and coulnd'nt find anything on this site, but i was wondering if anyone would know the benefits (if there were any) of having an AFM installed in the cooler piping (after throttle body apparently), as apposed on having it on the intake piping of the pod filter.
cheers JT
https://www.sau.com.au/forums/topic/96538-afm-location-benefits/
i've considered this myself ..
my conclusion was that it may be affected due to the temp of the air passig through it at any given point ..
IE . after the turbo the air would be hotter than ambient.
after the intercooler . the air would be cooler..but closer to ambient temp
i thought that this may affect it due to the AFM being a hot wire type..
if anyone would confirm that would be great..
search button is generally a good spot.
use alternative words etc etc.
although AFM will have it, you'll just have to spend 5-10mins loooking through everything thats all as it going to get a lot of threads of various natures
We often use post intercooler AFM in supercharged AU falcons as the standard length between throttle and AFM is about 30-40 cm. So when you introduce a intercooler with 2 meters of piping with the AFM placed before the supercharger you get a lean acceleration condtion on rapid throttle transitions. This only comes about because the standard ECU is calculating the air to be only 30-40cm away. That said the standard nissan ECU is calibrated so it expects the the pipe length, IC volume etc,ect into its calculations. It will have minimal effect if the AFM is placed before or after the IC as the AFM calculates the mass of air entering a cylinder.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
