OK there seems to be a lot of interest. I'll order what I can and let you all know when they are in my hand before I take money off anyone. I'll have to confirm the price as I'm not sure how much the postage will be. I will offer them in order from who replied first on this forum sound fair.
  • Replies 109
ok man, screw that paper model, the damn front end is CRAZY to get right...
Yeah it is, took me 3 or four goes to get it right, but now I have about 4 of them on my desk :)
Oh and great idea for the model Emanuel and sorry for hijacking your thread with the paper thingy :P
Where's the picture? :)
Furthur up in this thread :)
And for those of you who are cheap arses like me, build one out of paper :D
http://www.nissan.co.jp/EVENT/PAPERCRAFT/PDF/stagea.gif
Other models can be found here:
http://www.nissan.co.jp/EVENT/PAPERCRAFT/s.html
And other makes/models here:
http://www2.nkansai.ne.jp/shop/first/pcraft/t-models.html
Thanks to Squizz for sharing the link :(
Work.......? What is that?? <busy cutting up the calsonic paper model> :D
Aaaaaaanyway, back ontopic, I wouldnt mind a model, but dont have the patence for building models, never have.
On the other hand, I wounder if you could get a Stagea shell for a 4wd RC car.....?
Work.......? What is that?? <busy cutting up the calsonic paper model> ;)
I'm with him!
I suck at "teh model making" so I won't even bother putting my hand up, as much as I want one! I'd just ruin it and then be p!ssed off at myself for rushing it. :)
However, if anyone should happen to find a 1:18 scale die-cast Stagea, I'll DEFINITELY be in!
Price $35 deliverd Anywhere in AU or $30 pickup. They cost be a bit more in postage as I order all they had, 6 so 5 to sell. They are coming from Germany I had to pay in EUROS to get them. They should already be in the post to me.
The list:
Terminal
Stagen
AlexCim
beastien
bwilkeson
Burns
Muck
Mcnmg
qikstagea
ian
There are 10 on the list only 5 available, I'll update you all then they are in my hand.
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
