  • Replies 114
Posted Images
quite possibly that would just be from an external accelerometer than something in the ecu? what other things are on the dash? if theyre largely mechanical type things (rather than typical sensor readings from consult) then id say thats what it is
does it say anything in the service/user manual (if there is one?)
Edited by NewKleer
The R34's show the G-sensors digitally on the dash for 2000 models up, and mechanically for 98-2000 models.
The R32 GTRs and GTS4's have a couple of G-sensors around the place, but you don't get to see what they're doing. I think they would go to the ECU though.
I'm pretty sure the g-sensor would need to report to the ECU for ATTESSA functionality, unless of course there's a sperate unit/controller for it...
Also, just to confirm... HICAS is also controlled from the ECU? Or does it just manage the steering angle sensor and the like somewhere else?
Re: G-sensor ECU input for R32 GTR. The last few pages are the relevant section. It's the Autospeed article on the R32 from years back.
Thanks for the article, which for those that havn't read it, explains how to intercept the signal between the accelerometer (g-sensor) and the ECU. Which also allows for modification (i.e. piggyback system).
However, what I'd like to do, is read the sensor output voltage from the ECU (via the consult port)
Suppose we could try some reverse engineering.
trying to read g-sensor via consult port would mean reprogramming the ecu (and knowing how to do something like that). would take 5% of the time of that to just read the voltage directly from the sensor.
The documentation I have read implies that there *is* a consult port (that is, it had an id byte after a two byte initialisation)
it just doesn't seem to be wired up.
Of course, I could be wrong.
though it appears that all the computers get *all* their data as sensor voltages.... ahh, the possiblilties are endless
(when I make that attessa controller, I'll share it with confidence - as opposed to state my theory and get shot to pieces)
While I'm at it, I'll ask this question:
What are the inputs to the hicas computer, AND how does it control the pump (r32).
heck - the same with attessa. I have partial information on the input, none on how it controls the centre diff.
I suspect I'll need to get at it with a multimeter one day...
supposedly air con, hicas, and auto transmission can be queried via consult protocol, but ive never had success. i saw a table of whats supported in what vehicle, and i think the common cars only support ecu, whereas gtr and z32 (which ive never tried) support some of the others
Consult and Conzult work with AirCon, Hicas and Auto Trans in the Z32's. They each have their own seperate control unit but all read from the DDL.
quote=NewKleer,31 Jan 2006, 06:26 PM]
have released an alpha version of ecu talk while or work on the consult lcd
http://www.ecutalk.com
needs .net framework 1.1, links on the downloads page there
Edited by NewKleer
on my r32 gtr the hicas ecu wont respond to the initialisation unless there are delays between bytes but the engine ecu responds with no delays could be to do with the extra distance to the hicas ecu in the boot or even the different processor used by hicas, my ac ecu also remains silent with no delays but i have only just discovered
the need for delays and have not tested for the aircon delays yet.
i read that plms have to send initialisation more than once sometimes they are possibly not using delays.
my hicas responds to hex ff ff e4 with 10 then i send d1 f0 hicas then streams the error codes FF020000 ff start byte, 02 number of data bytes following, 0000 error code bytes ie no errors when ignition was last turned off
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
