hey guys
How much power can you make on a stock GTR cooler,GTR afm's and injectors
Iam going to rebuilt the motor with forgies cause the motor is dead and while iam there iam gonig to put some Garrett GT2860R's, so i want to run the motor on stock cooler injectors and AFM's while i save for better ites.
thanks
cya
david
Edited by divi
https://www.sau.com.au/forums/topic/96813-r32-gtr/
Hey
I have ...
R34 N1s
forged internals
Tomei CAM gears
std injectors
std AFMs
std FMIC
Tomei fuel pump
SX fuel reg
I run a max boost of 18psi with Apexi PFC and EBC
and get a wopping 300awkw - that's about the limit for the std injectors tho . and my air temps are creaping up there too.
I'd say I have pushed things about as far as you can go
https://www.sau.com.au/forums/topic/96813-r32-gtr/#findComment-1757433
champ did u mean 300rwkw rather than 300awkw???
just curious :D if it was a spelling error
Hey
I have ...
R34 N1s
forged internals
Tomei CAM gears
std injectors
std AFMs
std FMIC
Tomei fuel pump
SX fuel reg
https://www.sau.com.au/forums/topic/96813-r32-gtr/#findComment-1758596
Well - I had a 2wd test - and pulled 297rwkw (just over 400hp)
I then had an AWD test (different dyno) and got 293.5awkw
not that much in it - but they were different dynos
https://www.sau.com.au/forums/topic/96813-r32-gtr/#findComment-1758803
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
