It could also be argued that that power figure looks a tad optimistic for an automatic RB25DET with the mods you have listed.
I thought my graph was optimistic until I saw this thread.
3 inch turbo back (stock cat)
FMIC
EBC
Pod
on Auto R33 GTS-T
It gave me 190+ (192 I think) but timing was all out so the setting on the EBC was put back a tad.
I'm contemplating a SAFC2 and I hope it will give me 195+.
  • Replies 75
This is an interesting thread
Security: Lets not mislead people into thinking that 50rwkw gains are achievable through the use of an S-AFC, especially on a car like yours that is virtually stock because they arent - end of story.
The ONLY way that you could find that much more power is if your car was running like absolute shite beforehand. The gain is not soley attritbuted to your S-AFC.
I'm thinking that his base timing was way off. Majorly retarded.
That's where the gains were had, I'm guessing.
Can someone explain how the timing or "base timing" as mentioned above can be changed? Last tune, only the SAFC was touched, nothing about timing at all - just wondering if this would help me squeeze past 200rwkw (only out by 5.4rwkw at the mo.)
I think the only way to do it properly is a replacement or piggyback ECU.
Base timing can be checked with a timing light.
It is adjusted by turning the CAS.
hmmmm picture's would help ay...
I have 255rwhp in an auto and you cant compare it to a manual
and 50rwkws could be gain if it was running like shit on 92 oct
and serviced air leaks fixxed 98oct and a border line good tune close to blow up
sit am wondering the psi run
turbo mabe hiflowed
james
well Nick, if you read my post properly it says he played with my timing also.
apparently my timing was off to begin with.
he advanced it half way through the tune when it reached around 168kw and it jumped to 184kw.
my point of this thread is that he actually picked this up. not only did he tune my safc, he also fixed my timing problem. its for that reason i thought i had to post this thread... he definately knows his cars.
CAS = ?
Sorry about the questions, just interested to know. Autos are very limited in what you can do to tune them, especially in the R34 where the stock ECU is quite stubborn :(
and just as a direct reply to your post.. 50kw is 50kw.
if the dyno was reading high then it doesnt matter does it?
my base figure would've just been lower also which still doesnt change a 50kw gain.
and ive also said that he played with timing and allowed me to close the gaps on my spark plugs.
tell me another tuner that would allow you to do these things and give the same power output for the same price (it cost me $200)
Great, im really happy for you, but perhaps you didnt read my post. I was making a general statement and hoping you would post your before dyno sheet and or clarify specifics of what hitman fixed up to bring your power up (which you have now done)
Dont get me wrong, its a great gain, but for the 3rd time, i was simply saying it is always a good idea to confirm for everyone what was going wrong before so everyone understands where you made up the 50rwkw so people dont incorrectly assume that if they go and fit an S-AFC they will get these sorts of gains.
Either way, it looks good, and your car should be a different car now :(
any shop will be able to do it considering theyve got a timing light.
I havent seen a shop that doesn't have at least one timing light
Timing on rb25's should be set at 15+or-2 degrees at 650 rpm .
What was your timing set at before ? It can make a lot of difference .If retarded it wont have any power , if advanced to much it may ping ( knock ) and you may blow it up .
I dont doupt the 50 kw increase if your timing was way out , but the power your car is making is fat to optimistic in my opinion . As i said before its an auto and you have the aid of the torque converter and second gear .
A good way to find out the true power that your car is making , take it to wsid and see what your terminal speed is , thats a very good indication of your average power .
im pretty sure my timing was off.
i posted a dyno graph showing the before and after curve.
so just to clarify, i got 147 on 3" turbo back, fmic, pod and 12psi
with retarded timing (i THINK it was sitting a few degrees under stock).
if my timing was spot on then im guessing i would've made around 160kw as my base. but you cant really tell.
also another thing i'd like to add is he said that sometimes the knock sensor on the safc screws with the timing, if the knock is high then somehow it will retard timing so he advised me to disconnect it.
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
