  • Replies 41
u bet, 1st day i have off, headunit will be installed (hopefully headrest TV's and 2nd DVD player + PS2)
aswell as me lowering that baby to the ground.. mm 4cm off the ground *drools*
guess ill have to make that exhaust abit louder too *pulls out drill* j/k
when you lower a car too much, you reduce the suspension travel, thus resulting in reduced performance of the car.
Exactly, Nissan designed the Stagea to operate within certain heights, you can lower it a fair bit. But once you get to slamming height;
1. There is no travel left to absorb bumps, it hops from bump to bump. This means no steering, no braking and no traction to accelerate.
2. It hits the bump stops regularly, this means a harsh, uncomfortable ride. Add that to the most likely excessively high Japanese spring rates and you have a Stagea that no one will want to ride in.
3. Because of the Nissan design paramteters, the suspension geometry goes all to pieces, it will have too much negative camber and wear out the tyres fast. You will have silly stuff like 245 mm wide tyres with only 185 mm touching the ground. This means no steering, no braking and no traction to accelerate.
4. The drive shafts will be at excessive angles this means they soak up lots of extra power, this means slower acceleration.
That's why we say LOW IS SLOW
:P cheers:)
PS; I came back because I couldn't stand the thought of a slammed Stagea with 250 4wkw killing people because it wouldn't go around corners, won't stop and starts flying through the air at the smallest bump. We have lost too many Skyline owners to that mentality.
well more of what i was saying is, when i get home, im going to slam it to see how pimp it looks.. then raise it so i can get out of my driveway....just so that should mean instead of the car being @ 20cm off ground, maybe 8-10cm :) we shall see
^^ thats worse than 4wd :)
Measure the height, centre of wheel to guard. Standard is around 385 mm front and 375 mm rear, that is around 5mm lower than brand new. The lowest you want to go and keep some suspension travel and sensible geometry is ~350 mm front and ~340 mm rear.
:) cheers :)
PS; That is what mine is in the pictures
Mine is about that height too SK, it looks a lot better but still handles well enough.
I have a bad problem with camber, as i'm running a whiteline camber kit, but it's still about -1.5 degrees out. the guy i went to said he can put some adjustable camber bars or some such thing in, apparently he said they use them in race cars to negate the rear camber. fully adjustable setup.
tough as a bowl of custard! nah just kidding thats an awesome colour, id buy it anyday. an S2, aswell. Was thinking about 34 taillights for mine, but you'd have to split them in half, i think...
another body mod to think about - suicide doors for the back. gangster caddy style. if your going to airbag it, go some spinners. not my style, but if your gonna go halfway, might as well go the rest.
ps mine sits more NAVARA than stagea too - seriously after some suspension. just a hassle getting it.
im going for a more function over form approach atm. get it going quick, handling well, and stopping when i tell it to, THEN ill worry about how pretty and babe pulling it is.
Edited by qikstagea
I am a bit confused, sorry I need some help;
1.Is that front or rear camber?
2. What does "-1.5 degree out" mean? The recommended rear setting is 0.25 to 0.5 degrees negative, so is yours 2.0 degrees negative? The recommended front setting is 0.5 to 1.0 degree negative, so is yours 2.5 degrees negative?
3. If front, you must have something bent, 2.5 degrees is unreachable with the camber adjusters set on max positive adjustment (regardless of how low it is). Best to find out what is bent rather than patch it up with spherical jointed arms.
3. If rear, you need 2 camber kits. One for the inner upper on the control arm and one for the outer upper. The outer bush is in the upright (hub), so has to be removed unless the workshop has a special tool for removing the bush while the upright is still in the car.
This thread explains why I don't recommend using spherical joints in road cars.
http://www.skylinesaustralia.com/forums/in...64&hl=spherical
:P cheers :)
Edited by Sydneykid
Sorry. it's rear camber. i must have said that a bit odd, sorry not a suspension mechanic. i meant it was at -1.5 degrees on the rear, even after i'd had a camber kit installed on it.
maybe i just need to get another camber kit installed, i'm not sure if i did get 1 or 2 put on originally, but the guy i got to install it knows his stuff, so i'd assume he's tried everything to get it straight.
My car arrived last night, its much lower than I first anticipated...Scraped it a few times already, exhaust sits very low. The ride is fantastic! Very firm, is that how they are supposed to be standard?
What are the centre of wheel to guard measurements?
Should be around 385 mm minimum on the front, if lower than that chances are they not standard Stagea springs.
:D cheers :D
i think u might have aftermarket if its sitting low :D
which would explain why its hard.
not going spinners on my stagea. not my type either
suicide doors sound pimp and i want NOWW!!
i think ill organise rims, stereo, airbags, powermods, then suicide doors.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
