Hi all,
i have just installed a Blitz DSBC (Silver casing and blue back lit screen). Got it put on the duyno and have found out my fuel pump has had it....
Was driving home today and put my foot down a little and it seemed to do the misfire thing (as this is an Bosch fuel pump that just kacked it) (not sure whether its not flowing enough orhas shat itself) anyway it seemed to do that boxer engine type noise but along with a bit of a "chirpy" type noise as if it wsa coming from the turbo.....Decided to limp it home safely....
Im wondering whether it has been set up with too much boost and its just leaning out with this pump. That sed is someone able to tell me how to setup my boost controller so it runs as little boost as possible..possibly supplying a phone number?
Or do you think it may be that from the addition of this controller then boost is coming on stronger than before i.e. more earlier causing a misfire earlier or....????
Any help is greatly appreciated.
Cheers David
https://www.sau.com.au/forums/topic/97010-blitz-dsbc/
I tried moving it to off mode...did that... this but it would still register boost and if i put my foot down it would boost to like 1.3 bar
which is not to health for my stock turbo
and now im scared if i do try it again it will blow the turbo!!! help!!
https://www.sau.com.au/forums/topic/97010-blitz-dsbc/#findComment-1761088
Then it's probably been installed wrong. What boost did the car make prior to installation of the dsbc? Check the little switch on the back of the unit is set to "ac" and not "wg". The stock 32 actuator should make a maximum of maybe 12psi before dropping back to 10.
https://www.sau.com.au/forums/topic/97010-blitz-dsbc/#findComment-1761506
Made like 11 psi with tapering back to 9 or so in the higher rpm....however as the fuel pump was f**ked she was running a litle lean....(12.9)......but that was without the boost controller installed when she went on hte dyno......ill check that....but not sure i kno what i am doing....instead of trying to stuff around with it to much...shud i just leave it and just baby it until i get it all tuned and a ne wfuel pump done??
https://www.sau.com.au/forums/topic/97010-blitz-dsbc/#findComment-1761594
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
