Hi all,
Lately ive been hear this annoying rattle from my rear seats as if they are not in propoerly (in a R32 Gts-T). Has anyone come across this problem before and knos how to fix it permanently? I kno its the seats as when u push on them when it does make the noise it stops immediately.
Cheers, David
https://www.sau.com.au/forums/topic/97175-annoying-rattle-from-rear-seats/
The upright part of the seats are bolted at the bottom and clip in at the top, and the bottom part clips in at the rear and bolts at the front. if they arent clipped in or bolted tight they will rattle, check to see that they are, unfortunately you have to take them apart to check.
If they are anything like the R33 GTS-T seats, they have kinda hook things that MUST go over the attachment at the back in order for them to sit right. If they dont sit right, they will rattle. Simple fix is to take the seat out and put it back in properly.
Again, thats for the R33 - i'm not sure if its the same as the R32.
Justin
is it a constant rattle or just when you go over a bump or something i have the same problem just trien sus out if it is the back seats didnt actually think about it myself. but when i go over bumps sometimes i get more of a thuding noise than a rattle is this what you get or is it like a screws loose kinda noise?
cheers simon
Hi all,
Cheers, David
You're sure it's not the rear suspension? have you got aftermarkets in there?
I have Apexi N1's and mine rattle all the time... Im not sure what it is causing it, but its quite noticable, and sounds like the seat rattling...
ahh that might be my problem too i have aftermarket suspension hmm ohh well im over searching i took out the seats and no problem there
If it is the suspension I had a rattle like that after new rear shocks were put in, I took it back and they couldn't find anything wrong!!! Ended up taking it to Kieth for wheels in slacks creek and they hadnt located the shock porperly on the bottom (apparently easy to do) no harm done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
