i was just wondering...does a car that just had the head port and polished consume a lot of oil???
i got my head hi flowed about 5k ago and it seems to have eaten a lot of oil. is that normal? i used turbo light when i had the motor put together. i am going to use mobil 1 within the next couple of days. is it ok to use a full synthetic right now??? i've read that u shoud use mineral oils when you first rebuild a motor.
any advise would be great!
thanks!
https://www.sau.com.au/forums/topic/97267-port-polished-head/
from what you said - you got your head ported and polished.
if you didnt get a full rebuild then you should have to worry about oil.
If your car is chewing oil after getting a port and polish it sounds like they might have done a dodgy job. Take it to a mechanic and geta professional opinion.
Is the car blowing smoke? Any oil leaks you can see on the ground? It could be many things that are making it chew oil.
My car has done 130,000km (RB20DET) and it doesnt chew one bit of oil, has never been rebuilt or looked at.
best of luck dude!
I have had my 33 gtst for 2 years, and traveled to QLD and back from Canberra once, many Sydney trips, plus coastal trips as well, also WISD and not once has it ever used any oil. So i think there maybe a problem buddy get it checked out you may have excessive blow by, check the intake pipes for that. Good luck
also do a compression test that may shed some light on the problem, change oil. I use a 10w 50w semi senthtic
Edited by race_snooze
Shouldn't affect oil consumption at all (other than perhaps by an increase in performance, but certainly not to the extent of blowing lot's of smoke).
Something else has happened - eg valve guide seals installed incorrectly or not at all (don't laugh, saw that done once by a 'professional mechanic').
You need to talk to whoever did the head work or re-assembled the head.
iv also seen an oil leak on the top of the engine. where the breather hose goes. (where you plug in an oil catch can) seems to be leaking from there and spraying everywhere on the turbo side of the engine.
But...what could be causing the black smoke???? where is that coming from????
get a leak down test done on the engine. It sounds like you have a fair bit of crankcase pressure if it's blowing oil out the breathers. Once you have some results it's easier to diagnose what is wrong. Porting the head wont make a difference to the oil consumption if everything was done properly.
Black smoke is not oil burning, but excess fuel (ie rich mixture).
your right, he needs to confirm that it is black smoke or blue smoke.
black = fuel.
blue = oil.
compression test required for sure.
i was told by a friend that was driving behind me that it looked black, but that was at night... i looked at it during the day and it looks greyish/bluish. i have a feeling it might be loose rings.
i only had the head polished because i needed the exhaust valves replaced because my ex mechanic stuffed up my timing belt when replacing the water pump. i think the rings could've been damaged then???
if it is the rings, i was thinking rebuild??? does anyone with a built motor have any sugestions?
proengines is pretty much exactly on the mark imho. my rb26 had this problem, blowing oil outta the breathers because of a cracked piston ring land and boy did it use some oil hahah, filled the 2 litre catch can in about 10 min thrashing. all the compression is just blowing past the rings into the sump and causing a pressure area and therefore pushing the oil out the only way it can, through the breathers.
leakdown test time i think :)
the joys of imports hey :cheers:
Brad
what do they do exactly in a leak down test??? i know its ment to be more accurate than a compression test (i know what that involves)but what do they actually do??? and how much would it cost?
if the rings are stuffed...should i rebuild the block?
can anyone recomend a brand of forged poistons??? should i use gtr rods? what turbo is recomended for great power thats not too laggy???
Apart from telling you that all the info you seek is already on this great website I have the following info.
Leak down test. Remove spark plug and force some air from an air compressor in there measuring with a guage what leaks down, ie what gets pushed past the rings and valves.
cost dunno - allow an hour at least on an rb25
yes rebuild the bottom end if they are stuffed.
plenty of recommendations on here about pistons, some dissagreement too :D
What is great power? what is not too laggy? GT-RS might be the go.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
