Condition, shaft play???
Negotiability
Working Order??
Pick up or Delivery???
Kays??
has next to no shaft play in good condition pulled it off about 12 months ago when i fitted top mount if u are in brissy will meet you some where or im on the south side
https://www.sau.com.au/forums/topic/97274-turbo/#findComment-1766654
mate do you still have this turbo,can you send me pics im keen as apples.. :P
https://www.sau.com.au/forums/topic/97274-turbo/#findComment-1799381
  • 9 months later...
