EL GUAGE Dash Kit... white dials, blue at night to fit R33 GTS-T. See attached pic. Brand new in the box, was a gift, haven't had a chance to put it in and now selling my car so it's no use to me.
Retails $250
Asking $200 firm
I'm in Sydney, prefer Sydney buyer but will COD elsewhere, buyer pays COD fee.
Email: [email protected] if interested
Pic below is an idea of how it looks like at night, other pics are of actual item for sale
CMS: first pic is just an idea of how it looks like at night... the other pics are of the actual thing I got here... you can see in the third pic that the factory boost guage on R33 GTS-T's is still used on the white dials.
Brody: I believe Unique auto sports sells them, not sure if they are available for R32 and also autojoy.com.au
update: it's on hold for someone atm till 20th Feb, if this sale doesn't go thru i'll let you all know.
Will update soon.
Scotty: $200 is the price im holding onto, it is brand new and untouched, cheaper than retail. I believe COD would be around $15 if i remember to Melbourne. Dark is correct, there is clear plastic as can be seen in the 3rd pic
Cheers
  • 1 year later...
  • 4 weeks later...
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
