This Low K 1996 car is good for 500+ Hp at the wheels and over 800nm of talk :> is just been finished rebuilt with new motor and forged Aries pistons, new triple plate OS Gekin clutch big injectors fuel pump, drift king height adjuster coil over suspension adjustable camber rods strut brace big front mount cooler 700+ hp high mount turbo Apexi exhaust manifold full 3inch+ HKS super dragster exhaust system, Apexi external waste gate in to 2.5 inch screamer pipe, big oil apexi engin oil cooler kit. Eboost controller and Modified computer lots of gauges and sick body kit and 3 piece rims! Turbo timer and alarm one of best looking cars around demands respect money needed to complete new project car :> $19,500 ono comes with spare S2 motor and Apexi R6 modified turbo needs bearings. Just check out the pics :> Call Jeff on 0438513039
Edited by jmcdonald
What is going on here is this to exspensive the car has had as much spent on it as I am asking for the whole car just about? Come on this car is near new someone must want to make me an offer at least? :< would like to sell this car and get the new project on way peoples :>
The engin was done buy a local engin builder I have just finnshed the first 1000km I took the turbo off for the first 1000km to ensure the engin was run in perfectly am putting it back on this week end and getting it Dynoed buy Doctor Drift in Melbourne he also knows a bit about this car for people wanting to check up on it! I am about to email people some more pics :>
I will get some more info on the injector for you it is setup to run apexi R6 turbo but that needs new barings has a new turbine and housing just needs the barings so I have put just a generic 700+ hp turbo on it to sell it but you get both turbos with the carb I am based in Taralgon the car made 300kw and 800+ Nm of tourqe at the wheels at 14psi that was with less mods and the smaller turbo than it has this time should be dynoed this week with the new motor and gear
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
