Hey guys im just new on here. I did Join last year, but i havnt really had a computer until now, so this is the first time ive gotten onto here in a while.
Anyway just thought i would introduce myself and say hi!
Im from newy, and own a R33 as pictured.
Also i didnt know if there was an "introduce yourself section"
So sorry if its in the wrong forum!!
Cheers
Dave
Edited by weapn
https://www.sau.com.au/forums/topic/97943-hey-guys-im-new/
hey!
welcome... im from newy too- my name is manda. drive a black gts 33. i see ya round sometimes.. u mite not notice me  :) prolly see ya in town.
Really?
Have you got photos of your skyline?
Ill be in town tomorrow arvo?
Ill be sure to wave to you next time. :)
https://www.sau.com.au/forums/topic/97943-hey-guys-im-new/#findComment-1778964
Hey dave, nice to see you finnaly joined.
I see the purple flash streak thru Charlestown sometimes and occasionally grab EVERYONES attention when you lurk past the foreshore.
Unbelievably nice car you have mate - the cars a tribute to ya - hopefully my car may be as impressive as yours one day.
Ill stick my hand out and wave next time i see you. Not sure if you've seen my car around newcastle much.
You coming on the Newy cruise on the 18th to Solidiers point?
Link is here: http://www.skylinesaustralia.com/forums/in...showtopic=94348
Be nice if you could make it along.
-Dave.
https://www.sau.com.au/forums/topic/97943-hey-guys-im-new/#findComment-1779193
Cheers
Dave
I've heard about you before, I hear you're trouble!
She mentioned a skyline in newcastle with the plates weapon!
https://www.sau.com.au/forums/topic/97943-hey-guys-im-new/#findComment-1779256
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
