  • Replies 180
hehehe well if your seriously interested.... im thinking i might need an assistant in about 2-3 months once my business is fully set up...
It would be pretty easy... just hadling some admin, like contracts and stuff, and the initial enquiries from vendors and buyers... Coming to help with open houses, listings and auctions...
Its pretty fun actually...
Dont know how much id pay you hun... but you would get a laptop and pocket pc as part of the package...
Originally posted by MZNISMO
looks like im moving to queensland in 2-3 months then
im serious i need a change!!!
matty gimme details and stuff in pm if you absolutely serious bout it but
yeeeeeeeeeeeeeeeeeee!!!!!!!
hahaha!!!
u need a change from bludging at wor all day??
matty what business u opening up?
Property Sales and Project Marketing company. We will only be handling prestige properties.
Still a few things to sort out legally and alot of planning/research left to do... But its kinda exciting :) I did all the branding the other week and it looks really good.
Ambz, il send ya a pm later with a few websites to look at ok? :)
Originally posted by SmoothLine
Nope not a huge amount.... thats why its taking a bit longer... to minimise the financial risk...
I'l have it set up as a sub-brand to a pre-existing company... Thats why there are a few ASIC issues to be sorted...
Smart ay? :)
yep very, then u can always blame the sub company when u get investigated for corporate fraud, once ambz starts working there, that is!! :)
Originally posted by Milk
haha
u guys so funni
hey anybody so free to take me for a ride?feeling boring the first few weeks of uni
hahahah
if u want to feel what a real sports car feels like, u r gonna have to ask ambz to take u for a spin in her opel calibra!!:bahaha:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
