Greetings,
My 4WD Light has started to come on, the LED light in the boot is flashing 21 times, could someone who has a SKYLINE manual PLEASE de-code this for me!
Cheers
It is trying to tell you something is wrong with the throttle sensor or circuit.
Could you please tell me where the Throttle sensor is located and if I would be able to fix or even replace with little knowledge of the ATTESSA system in the R32 GTR,
or is it a case of finding someone with the knowledge and TOOLS
Cheers
From the little I know, wouldn't the attesa be reading the ecu for the throttle position sensor?
I know that hicaus reads information from the ecu. why not attesa?
At least it appears that way to me when I looked at the spec sheets that are provided by plms.
perhaps if you PM'd "New Kleers" he might know. Then again, he might not, and I don't know him.
also, not that I have done it for this, but this sounds like something a search would turn up
-> good luck.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
