Noticed the other night driveing home that i now for some reason have no headlights. The rear lights, dash lights and parker lights all still work, and one of my high-beams still does, but the other high beam and both normal headlights aint working. Ive checked the 2 fuses under the hood, and even changed them just to be sure. Ive also changed one of the non working headlight bulbs, but still no good. If i use a bit of speaker wire and wire it directley from the battery straight to one of the headlight globes it will light up.
Just hopeing for anything else i can try or look for before i take it to an Autoelectrician and leave the car and a blank cheque with him.... :)
Thanks guys.....
https://www.sau.com.au/forums/topic/98485-in-the-dark/
The combo switch will affect the low-beams. Often, in the early stages, if you jiggle the switch a bit you can often get them working. The switch can be pulled apart and cleaned up as a bandaid.
The high-beam problem is probably a blown globe.
https://www.sau.com.au/forums/topic/98485-in-the-dark/#findComment-1791475
Mines done this.
At first the right low beam would just drop out, give the dash switch a wiggle or switch it off and on quckly and both would come back on again.
After a while both lights dropped out, leaving only high beam and parkers.
I had the auto elect replace the switch. 6 months later it did it again.
I ripped the dash switch out and soldered the contcts together so that if one earths they both earth. You will see what I mean when you pull the switch apart. The problem lies with these little plastic lumps of plastic that are used on a roll type switch to place pressure upon the contact to earth it out.
The plastic appears to melt causing the contact not to make contact properly. Hope that makes sense. :)
As a bonus the low beam now stays on when I switch the high beam on. Its been like this for 3years without a problem.
I am a little nervous about leaving the high beam on for long periods of time as I fear it may be overloading the switch having both low and high on at the same time.
Edited by Cubes
https://www.sau.com.au/forums/topic/98485-in-the-dark/#findComment-1792581
Thats exactly my thinking.. BUT why is it generating enough heat for it to melt the little plastic lugs that place the spring loaded pressure on the metal contacts in the first place.
Its rather common for R32's to do in their lightswitch.
The Auto elec, (who owns a rather tweaked R33) said he's had quite a few R32's in, he solution was to completely bypass the origional relays and wire up his own. ~$180 he quoted, bugger that I can do it for next to nothing myself. :D
Either way, my bodgy mod worked, has for 3years if not more.
The years are flying past, I've had the damn car for 4years now :)
Edited by Cubes
https://www.sau.com.au/forums/topic/98485-in-the-dark/#findComment-1792654
It all goes through the combination switch on Nissans.
No Relays.
Thats why you have so many contacts on the combination switches and the reason they fail all the time.
As soon as the contacts get dirty, causes high resistance, then it gets hot and melts the plastic.
Nissan skylines, navaras, patrols etc are all the same.
https://www.sau.com.au/forums/topic/98485-in-the-dark/#findComment-1793092
Being strapped for cash at this time of year especially, i spent a bit of time today and simply rewired the headlights with some new wire and fitted my own inline fuse to a simple toggle switch, as a temporary solution. I ran outta wire though today, so for now the switch is mounted under the hood next to the battery, obviously ill buy some more wire and try and mount the new switch inside the cabin, until i can afford a new Nissan switch.
Just on this fella's, wheres the best/easiest place to get wire from the engine bay through the fire wall into the cabin, i couldnt see anything obvious today, but didnt look to hard yet...
Cheers....
https://www.sau.com.au/forums/topic/98485-in-the-dark/#findComment-1793638
Make sure you wire it up with a relay, not just a fuse. You can pass it through the firewall on either side. You should see a triangular foam blocker in the far corner where the inner guard meets the outer firewall. You can find this on both sides. It's tucked away down in a little hole sorta.
https://www.sau.com.au/forums/topic/98485-in-the-dark/#findComment-1793832
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
