/\/orthside Pizza Feast - Monday 10th February
The dinner ritual continues guys.
The next TNS dinner will be held at Gormet Pizza Kitchen at Chatswood next Monday february 10th at 7:30pm.
The restaurant is located on Archer St Chatswood just past the Victoria Ave intersection with ample car parking available just across the road.
Let us emphasise the need to be weary after last nights TWS ambush :uh-huh:
Will need numbers confirmed as soon as possible.
Nick
  • Replies 60
Mark - there is a police station opposite and you will be busy waffling down $3.50 budget steaks at St Johns........
Feel free to try and penetrate the TNS defense.... we got something for ya :uh-huh:
Will book the tables on the weekend as GPK normally gets very busy guys.
Those of you who are coming and have not yet confirmed, ie your name isnt on the above list please let me know asap
Cheers
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
