ok.. i know this might not be the best place to post this.. but............
ive got one of them victa tornado mowers and when i mow my lawn i do so every few weeks (read: months) so my lawn gets pretty bad.
sometimes my little victa cant handle it and turns off, then ive got to turn it back on and do the old "back and forth, lift" so it doesnt turn off.
anyways i was wondering if i could put 98 octane unleaded into it with maybe 1.25 bottles of the 2 stroke oil to give it more power.
would that work? what other things could i do?
https://www.sau.com.au/forums/topic/98754-more-power-from-my-lawn-mower/
  • Replies 46
Posted Images
Dude , you are not serious , are you ? You ask silly questions you get silly answers.
How is puting 1.25 lt of oil going to give you more power ? How is 98 octane going to give you more power? Its a 2 stroke with a 6 to 1 compression .
Dude... change the spark-plug on it too... sounds like something is overheating and dying on you. But like cars I guess, opening the exhaust, giving it more fresh air, and making sure the spark is right can only help.
98 octane fuel just means it won't pre-detonate under high compression, but a mowers compression probably won't go anywhere near that anyway. If you wanna use it to make your own 2-stroke fuel, go ahead =-]
maybe you should look at your approach.
the lower the mower rides the more work it has to do as the blades are closer to the grass. try setting it to the maximum ride height. this will help do a quick pass to trip the top layer off and it will be less resistance on the blades (like a bigger dump pipe on your gtst). also empty the catcher more often, more grass in the catcher means it bogs up the outlet more (like a non turbelance dump pipe) and this cause more "resistance", so empty as often as possible.
if you are really desperate you could skip the grass catcher completely and wire open the flap door for it, this will allow for minimum resistance and let the grass clear straight away (like a dyno run with the dump/front pipe unbolted)
come on dude, im no dummy.
i know the lawn mower is lacking power, so im just looking at my options in terms of increasing it.
thanks RANDY, helpful info mate.
shut up idiot.
I hope that wasn't directed at me .
I think we can all see who the idiot is . You want to put 1.25 lt of oil in the mower tank , how much do you think the tank holds? Why do you think you mix oil with petrol in a 2 stroke engine ?
Wind out the rpm needle and rev the crap out of it. Take off the air filter. Lean it out some more, but more than likely change the plug.
Or you could sit it there on the spot winding up the revs before you go over a thicker patch :D
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
