  • Replies 63
yeah any boost controller should be able to do that though, without a tune, user simply dials in pressure and thats it, some require duty to be set but it shouldnt any more complicated. there were always stories of the avc-r spiking lots and running unstable boost. if this is not the case with yours then its all good
Thats the thing Paul... A lot of the ebc's won't hold boost to redline IF the turbo is running near its limit. The EBC MUST be able to learn the duty cycle requried in order to hold the boost you dial in.
I used to run a Blitz SBC-iD EBC, it had the usual manual setup which uses a fixed duty cycle and gain. Then there was the auto where it used a fixed gain but would learn the duty cycle required through the whole rpm in order to hold say 15psi.
The Blitz SBC-iD has a little picture of the dual solanoid and what its doing, half open fully open or closed etc.
As RPM increased you could see the solanoid go from almost all the way open at peak torque then from then on it would slowly close holding the dialed in boost all the way to redline.
Selecting manual mode and dialing in a fixed duty and gain which is the basis of how the majority of EBC's (HKS, the lower spec Blitz items and a few others) work boost would tail off at high rpm. Run a big turbo that won't have flow issues on your motor on you don't need such an ebc, the manual types will do just fine.
My Blitz SBC-iD in auto mode did have a few issues with spiking as the AVCR also has IF not setup correctly.
It has to be setup on a dyno in fourth gear taken from low rpm all the way to redline, this can't be done on the street for obvious speed restriction reasons.
Set it up in second or third as I attempted and it would occasionally spike when jumping on the throttle around peak torque or when loading it up from low rpm.
I've had a little play and monitored bl4ck32's boost curve, I was very much impressed with the stability and lack of even the slightest spike.
The only reason to grab an AVCR over the PFC EBC is the extra features of the avcr, they both work exactly the same way, not one will hold or build boost better than the other. It is definitely worth while when running a decent 250+rwkw IF you are having a few issues with traction and have already sorted suspension/tyres.
So as with everything.. its all in the setup/tune. :)
Edited by Cubes
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
