this is how i did it in my r32 i have a greddy catch can i made my own 'bracket' out of this metal thingy that your guttering up works a treat and used to have it cliped around my battery but i have to turn it around and couldnt use the bracket dodgey! so i ended up shortening my 'bracket' and pot riveting it to the fuse box jigger above the battery as you can see ive followed sydneykids instructions and i have the full plumb back.
cheers.
ps sorry about the dodgey phone pics! :huh:
ahhh yeah to keep everything plumbed back so i dont need a filter suposedly if you block things off thats pressure and u need the filter but its all connect as if standard so its ok no extra pressure just running through the can
Wicked setup... I have bought a "Drift" one from Autobarn cuz the 1 litre Greddy one wouldn't fit in my engine bay... D'oh... (however, this Drift one does have an oil level pipe on the side, so you can see how full it is) But I was scratching my head to plug up the "return pipes" but now I will do the same as this one... Thanks for the pictures, and just in time too :D
gt-t r34 - I'd recommend going and spending a little bit of money and grab some more hoses clamps... for saftey and security on all hose connections... unless you were recommended not to use these??:D
Regards,
Grant
Edited by QUIKBLADE
I dont quite understand what you are saying
Jshop Catch cans are like the Autobarn ones with the Level on the side
If you're referring to what I've said... I don't know the J-Shop ones, but that's good that they have the level on them... at least you know when to empty!! :( Also, the Autobarn "DRIFT" branded 500ml ones (upon closer inspection) look like Greddy 500ml knock-offs :( But meh, should be just as functional.
Regards,
Grant
dont worry i was being stupid!
anyway as for those extra clamps i had cable ties on there coz i ran out of clamps but they must have cut them off when i got it serviced havent had any oil leak out and they are on there very tight ill just see how it goes!
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
