hey all, i have bought a n/a r33 through an importer in sydney and due to pick the car u soon today i sent an nrma inspector to check the car out
relly dissapointed the car has some guard damage some interior damage some exterior panel damage some under enginge damage which could effect oil pressure , knocking sound which is caused by some spring in the engine TELL ME THIS ISNT THAT BAD considering that i have spoken to the dealer and he said everything will be fixed and car will undergo detailing . is this normal in a way considering it has been on a boat , through customs and down from queensland p.s im getting the car for 12000 thanx !!!
https://www.sau.com.au/forums/topic/100121-r33-na-damage/
i wudn't touch it....
skylines are much much cheaper now... about 2 years ago (bit less) when i got my R33 GTS25 it cost me a good odd 16k.
1994 R33 GTS25 with 65000km with log books and all.
back then the supply was low with the high demand, and the expensive compliance plates (at that time about 5k)
now you have a much larger range and choices to choose from, if you dont like it and uncomfortable with it... just walk away.
eug
https://www.sau.com.au/forums/topic/100121-r33-na-damage/#findComment-1825439
walk away from it, it sounds dodgy. for 12k you get an NA in aus. it may not have the rims and bodykit but it also wont be damaged. but the decison is up to you, if the dealer is going to fix it most likely they will do a dodgy repair, and then when it comes time to sell it, you will have troubles.
https://www.sau.com.au/forums/topic/100121-r33-na-damage/#findComment-1826458
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
