So what mumbo does your car have these days Matt? Did you end up getting the APs liek you were planning? Suspension????
LOL..you know why im asking? And asre you going to make Calder?
lol yeah i know why you're asking :) havent done the 6-pots yet.. still on the 4-pot brembo's. as for power, have to wait and see when i get it back.. dyno tuning on tuesday so we'll see.... yeah hoping to make calder, faxed my entry form in yesterday. B)
  • Replies 53
lol yeah i know why you're asking :P  havent done the 6-pots yet.. still on the 4-pot brembo's. as for power, have to wait and see when i get it back.. dyno tuning on tuesday so we'll see.... yeah hoping to make calder, faxed my entry form in yesterday.  B)
I wouldnt waste money on 6 pots matt
I don't consider it a waste of money... I'll decide if more stopping power is needed after seeing how well the brembo's pull up with the power increase. Will you be competing round 1?
U wont be pulling over 400rwkw will u???
I am getting car back from ICE today but couldnt tune it properly coz it was a sweat shop on the dyno today. Gotta play with the suspension still coz i wasent happy it it last time at calder so not 100% sure
What tyres are you looking at runing INASNT? Whatever they are, put them on the car and go see Geoff at Techsport
4/3 Power Road
Bayswater
Victoria 3153
Tel. 03 9720 9300
He is over your way, champion guy and knows how to set up cars. Tell him its not your daily driver, so you want your alignment to give you the best you can get out of what you have....The settings between street tyres and semis is different, so make sure you have your track rubber on the car
no but i like to brake late into corners :P calder is a little hard on the brakes... the brembo's will still do the job, but i dont mind a bit extra in the braking department so why not B)
Roy i am looking at running a set of 17 inch semi's with some enkei's I am looking to get off wayne.
How much different does the alignment need to be as I recerntly got the alignment done with the new camber, caster bushes went in
Im running 2.2neg front and it is nowhere near enough with the shocks/springs that i am running. I need to get it back up to -3.5. That sux daily driving.
I think i have -1.8 neg rear and 0 toe which works really well with the swaybars on full hard front and rear.
Castor can stay the same, but things like Toe etc, plus i have read repeatedlythat if you want it done properly, you shoudl get it all dont with the exact rimand tyre combo you plan on running.
Thats far from expert advice, but its what i like and seems to work with my car
Yeh, kinda works that way...and on street rubber my car is fine...But with the semis on i kill the outside shoulder. At Sandown the front right tyre took a hammering. I have a bad habit of trail braking into corners which i think tortures the front tyres more then need be?!?!?!?!?!
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
