WTF is up with Chapps Tonight????
the only good thing about chapel street is walking down their going from place to place having a few drinks and checking out these fools !.
Exactly! Chappel street is just shit.. go somewhere else if you wanna do that. The cops have for a while wanted to end that culture because of many many complaints from traders and local neighbourhoods and they will eventually.
  • Replies 40
i usually go chapel st with my gf majority of the time on weekends. i park at jam factory parking, get out, walk to cheppallies, eat my food then go some record stores and borders and buy stuff.
i dont like driving past kfc unless its during the day when im going to my granny's or just need to get through there in the day time
It is one of the biggest social sceens, for the food, the bars and back when chasers was good, the clubs...
It aint about wankers doing laps though! thats so lame.... It aint about cars full stop. Cos the food, bars and clubs got there long before the car wankers did...
I am sure Ambz would not go that low... not since she woke up and left mccr anyway :D
lol@chap laps though....
The whole chapel st car thing started cos muzza posers wanted to try and impress the mafia guys who used leave thier ferrari's, porsche's and lambo's outside thier cafe's while they were having drinks etc. Then it just grew into people trying to look cool....
Pretty sad really! Cant look cool when your yelling 'checks out my ful sik kit bro'
many moons ago we were at an outdoor cafe, chillin', having a bud when we heard this loud bang. everyone stood up and started clapping. a barina with had hit a vn commo in front of him. looks like the 5 heroes in the barina were acting a bit too fulsik and didnt notice the crawl had come to a stop. vn driver gets out and goes fulsik on the guy in the barina for about 10mins.... funnniest thing i ever seen on chapel. :D
me too, I only drive thru chapel if going to the jamfac for movies, nothing else... as soon as movie finish n we're out o' the carpark, I just drive away as soon as I can n as quiet as possible from that area...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
