I am posting this car for a mate
About the car
R33 4 door skyline
RB25, 5 speed manual done 73500 kms
*Brand new custom midnight purple paint job
*Tinted Windows
*exterior and interior condition Immaculate!!!
*lowered on brand new pedders sports rider springs
*Alloy Wheels
RB25 Engine modifications inclue:
* GTS LINK engine managment (ECU)
*Garrett 550hp turbo (6months old)
*3.5inch mandrel bent dump pipe off turbo into a 3inch mandrel bent exhaust system with a 3inch hiflowed cat converter and polished stainless genie cannon
*Sard fuel pressure regulator
*550hp warlbro intank fuel pump
*splitfire hipowered coil packs
*600x300front mount intercooler
*autometer boost gauge
Car made 212kw at the wheels @13psi
The factory injectors have reached their maxium flow
All this car needs is a bigger set of injectors more boost and a tune and should have no problems chasing the 300kw mark at the rear wheels. Poor spark is not a problem with splitfire coil packs producing strong and efficent spark at higher boost levels
I have driven this car on many occasions it is very comfortable to drive handles great and has an awesome power combination, comes on to boost very quickly and not much higher than factory rpm levels
For Further information on this car you can contact its owner
Andrew on
41513141 durin business hours
or 0409592572
or reply here
if you PM please be patient as i will have to relay all messages through to him
Owner is looking for a cash sale
not really interested in swaps but no harm in offering i suppose
$16500ono
pics can be found at
http://www.boostcruising.com/forums/index....howtopic=113047
Edited by 21AZY
https://www.sau.com.au/forums/topic/100504-r33-4-door-sedan-modifyed/
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
