Hi, firstly I apologise if this is in the wrong section, as I wasn't sure if it should go in General, Handling etc. Secondl apologies if this has been posted before, I did run several searches looking for this information but couldnt find everything I wanted.
No doubt having said that, someone's going to post about three or four search strings proving me wrong, so apologies in advance.
Basically i'm after two bits of information.
1) Does anyone know of any places or sites that have lightweight flywheels of good quality. If physical stores, in the queensland region.
I know of Nengun and Modyourcar. Nengun have an ORC for around $550. Is this a good price?
2) My second question is for those who have taken the lightened flywheel route, for an everyday driver, what is a good weight to go for on the car? I see the majority around the 4.8-5Kg range.
I know that the lightened flywheel affects that ability of the car to provide torque, (in a sense) thus when the car has to carry more load it must work harder than normal. I was just wondering of any other side effects that are evident with a lightened flywheel. IE: Fuel usage, idle quality, highway cruising quality etc.
3) This is my last question I promise. What is a good price for a lightened flywheel, and is it better to have a stock one ground down/balanced and machined. Or buy a chrome-molly lightened one etc?
Thanks for your patience and thanks in advance to any input or advice.
-Tom
https://www.sau.com.au/forums/topic/100600-lightened-flywheels-on-r33-skylines/
Lightened flywheels have been covered many many times before on this board.
I found the car to accelerate easier from a standing start, gear changes at wot felt quicker and much less likely to crunch, overall there was zero negatives, zero difference in fuel consumption, zero difference in vibration.
yer the search function can be a bit of a pain in the arse some times. Practice makes perfect. :(
I'm soon to grab a lightened flywheel, this time around I will grab one witha replaceable insert. Ceramic clutch's hammer them.
Edited by Cubes
i second that! i had some mild wear and tear marks on my flywheel when i changed my clutch, at the time i couldnt spare the cash or have the car off the road for another week to do the flywheel properly so ye olde emmery paper had suffice as a temp thing. 10 months down the track ive noticed if im lazy with the gear changes it shudders like no tomorrow. Gearbox is on its last legs at the moment so ill do it properly this time round and get a new flywheel when the gearbox is done.
Thanks for the reminder cubes! After the box is done maybe i can join the RB30 club. I dont wanna do the motor if my gearbox is cactus. I might even try to grandpa the car round for an extra couple of months so i can do box and motor at the same time. That way the old man is happy because i wont be using his precious garage space.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
