Hey,
Fairly new here and id like to know some info on the the R34 Getrag 6 Speed since i am interested in using one in my R32 GTR that i have just built an engine for.
The engine will make around 450kw at all four on pump and is using a RB30 bottom end so it will make a fair amount of torque and i would like to know how strong these boxes are and if there are comparable in strength to a OS Giken Cross Gear Set 5 speed gearbox.
Also i would like to know what would be needed to install this box into my R32 GTR
Thanks
https://www.sau.com.au/forums/topic/100634-r34-getrag-6speed-gearbox/
cool, cheers guys. Ive got a OS Giken gearset being fitted as we speak someone mentioned the Getrag as an alternative so i thought id ask.
All i need now is a R33 GTR front casing to save me modifying the R32 housing for a pull clutch
Guest Mashrock
Hey,
Thanks
i'm using one in my 32gtr.
you need a 34gtr clutch and flywheel/ modified tail shaft and 34gtr propshaft.
could cost in upward of 8k..
so do the math.
but an rb30 into your 32gtr? what the?
