Hi all.. was wondering what everyone thought bout puting a turbo in a clean mr30 Sadan that i recently pick up. it has a rebuilt L24E, 5speed and IRS. To turbo i was thinking of finding a L20ET menifold and ecu do they bolt straight onto the L24E if so do i still use the L24e injectores and fuel rail. Also how hard is it to upgrade my motor to a Nissan RB30ET my mate is selling a worked one out of a VL Calais.. what would be involved in fitting it in the skyline. Also anyone with L20et parts they wanna get rid of give me a bell on [email protected]
Thanks for the help
Luke
https://www.sau.com.au/forums/topic/100836-mr30/
Luke,
I have one of the hatchback versions. I also investigated just grabbing the turbo gear of an L20ET and whacking it on the side of the L24. However, it was suggested it would probably ping its brains out since the combustion chambers weren't designed to operate in a boost situation.
But then, if you installed aftermarket ECU, it would obviously possible to tune it to suit.
I happen to have available a L20ET, that I ran in a 240Z for a while. It has since been modified with a RB20DET BB-centre turbo, as well as still having the gear to hook up a Wolf 3D ECU. Also has been modified to use a small intercooler.
As for the VL motor, I am lead to believe that basically all that needs to be done to install any RB-series engine into the R30 is to get hold of the R31 X-member, then the engine will drop straight in. Then of course, you need the RB gearbox, and the RB drive shaft.
https://www.sau.com.au/forums/topic/100836-mr30/#findComment-1840646
Luke,
hi man thanks heaps for the info y would it ping under boost i dont understand??? Also How many km's on your l20et might be instrusted if you where selling it. how much would u ask? $$$ B)
https://www.sau.com.au/forums/topic/100836-mr30/#findComment-1841185
I think it's because of the design / shape of the combustion chambers. Just what I was told, but the last thing I need is an engine that pings.
Probably 100k on it, but the L-series engines I have found to be almost bulletproof, not like the RB-series.
I replied to you "Wanted to Buy" with a price. That would include an intercooler, and the RB-series dump pipe. The engine is set up to run off a Wolf 3D - that is available also, say $300 for ECU + loom.
I'm in Melbourne.
https://www.sau.com.au/forums/topic/100836-mr30/#findComment-1841364
Let me ask some people about freighting it up there. I can probably do that price as a "delivered to your door" price, depending on the freight cost.
It should simply drop straight in and bolt up to your gearbox (as willl just about any L-series engine).
https://www.sau.com.au/forums/topic/100836-mr30/#findComment-1842236
I asked around and $350 for a compleat L20et with that many km's seems to be the going price... a mate scored one for 200 bucks with some barganin from the wreakers that had just been taken out of a dr30 or hr30 or something he was saying
https://www.sau.com.au/forums/topic/100836-mr30/#findComment-1842325
can i ask how much is your mate looking to sell the rb30et for?
the L24et should be good to run stock boost 6-8psi without problems, some tuning time will help, are you getting the wolf ecu? intercooler is a must to run higher boost plus nothing but BP ultimate too. engine will live a bit longer.
https://www.sau.com.au/forums/topic/100836-mr30/#findComment-1843376
i was either going to get a l20et motor wolf 3d and has been setup for a intercooler or just get my hands on a l20et menifold turbo and ecu would i use the ecu from the l20et or l24e
would my l24e with that l20et turbo setup running 8psi be reliable and last
also what power increses can i expect
my mate had a vl calais that he wrote off and is selling the motor and box for round $500 i think i will make sure and post a msg
https://www.sau.com.au/forums/topic/100836-mr30/#findComment-1843490
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
