Item: 1993 BNR32 - SOLD
Item Condition: Excellent / 92,000km / White
Price and Payment Conditions: $30,800 ono
Extra Info: See list below
Contact Details: PM / [email protected] / 0411 40 8856
thanks
glenn
https://www.sau.com.au/forums/topic/101072-1993-r32-gtr/
i can vouch for this car.
easily one of the hardest and fastest street r32 gtrs out there.
the owner is like a fussy woman, nothing but the best, no expenses spared and no corners cut.
https://www.sau.com.au/forums/topic/101072-1993-r32-gtr/#findComment-1845066
hey mate, sad to see your car go :-(
Good luck with the sale, very good choice of modifications on the car...really well put together!! One of the cleanest i have seen!!
cheers,
Francisco
thanks dude :O
https://www.sau.com.au/forums/topic/101072-1993-r32-gtr/#findComment-1885488
does it come with the scrunchy?
lol... i was just waiting for someone to comment on it...
no, it does not come with the car...its actually my wife's and it gives me 20 more hp :)
https://www.sau.com.au/forums/topic/101072-1993-r32-gtr/#findComment-1891265
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
