The 2835R turbos are probably the limiting factor on the R33 at the moment.They were chosen because on a 3 litre engine with 9.1:1 comp they give strong top end power & also come on boost relatively quickly - making the car very responsive for street use.
Now the car has morphed into a race car(is awesome on the street - but who am I kidding - it's no daily driver) the smallish turbos limit the current setup to around 850-900 hp.
I would like to fit 3037S & remap the motec to suit which should see the output raised to 1000hp without ringing it's neck - but
no-one has put their hand up for the 2835Rs & without selling them I can not upgrade.Larger turbos would increase lag, but on a car that rarely sees less than 7000rpm that would not be an issue.I would like to see the car run a 9.4 as it is - but drag racing is a funny thing. 9.6 might be where it's at, & thats fine.
Slicks would definately be faster.Possibly by 4or 5 tenths, but create other problems.For a start, there are 2 classes for GTRs -
"street drag GTR" running radial tyres (Nittos) or "Pro GTR" running slicks.It is much more than a simple tyre swap.To run slicks you must run 15" rims, which means removing all the GTR
brakes & running smaller non turbo style discs & calipers.Also the suspension has to be totally changed to suit the softer tyres.
another problem is that in Australia(under ANDRA rules) a 4WD is
not allowed to run non radial tyres all round - so unless it's an outlaw meeting at a non-sanctioned event - it wont comply.
The HKS car was exempt at Drag Combat last year as an exhibition car - but they nearly did not let it run as it did not comply with heaps of ANDRA regulations.The shock load through the drivetrain from a 4WD slicks launch can also cause severe breakages.It also means 4 slicks,4 rims, brake changes etc - add that up.Rather than do a bit at a time & slowly get the car into the 9s, I decided to go all out & stretch as far as I could.With the std engine my best was 11.10. Now with new engine my best is 9.66. That's a huge leap in drag racing.With fine tuning & 60' practice we may shave a tenth or two, but the next step into the low 9s could cost anywhere from $20-30,000.00
It's also about the look of the car. As it is it looks like a fairly normal GTR at first glance(I was driving down GJ rd recently & a copper coming the other way didn't even turn to look at it!)
With 15" rims, lexan windows all round,no headlights, & covered with stickers I think it spoils the look of a GTR.People can relate to it if if still looks like a street car.Hope the weather is good for Sat night - looking forward to 9500rpm & playing with my Holinger.
  • Replies 62
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
