mmm circus monkey has some taste in tuners. veilside last year, zenitani this year...
man they have some nice cars for sale.
http://www.kurumaerabi.com/?page=shop&stor...op&store_id=595
https://www.sau.com.au/forums/topic/101163-zenitani/#findComment-1847904
  • 1 month later...
Are there any telephone/address directory type-thing for Japan?
Yellowpages etc.
Theres one called 'Town Page'... but thats the local Hyogo one I'm refering to. Anything in particular that you want to find?
https://www.sau.com.au/forums/topic/101163-zenitani/#findComment-2016905
I have tried Town Page.
No, see if I an find an address/number from one person in Japan, I`m buying some stuff from.
https://www.sau.com.au/forums/topic/101163-zenitani/#findComment-2020571
