Try out an EVO 8 MR BOV, they're fairly inexpensive (unless you get it from Satan, uhh... I mean Mitsubishi), and apparently can hold near 20 psi, no problems. Even if it required some modification to fit, I would bet a dollar that someone makes an adapter for mitsubishi BOV's to fit skylines. But like Mr Italy! says, it's probably the same flange.
Also, a VR4 BOV is nice (mine holds 18 without too much hassle, will probably swap it out for an EVO one though), and should be really cheap. Call some jap wreckers.
https://www.sau.com.au/forums/topic/101186-gtr-bovs/#findComment-1850476
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
