Engineers, Anyone Know Any? Prefer Melbourne
hey thanks man!
hrmm thats gay, i read it all and it says it only lasts 30days, i though it was somthing you can carry around as proof your car is all legal. My car is already registerd with the rb25det so no dramas, but you know, the police :P
Being registered with an rb25det does not mean it is legal. :unsure:
But i didn't know about the 30 day thinggy.  There must be something that is permanent.
well yeh, other wise i couldnt register the car, its cause its a smaller capacity i got away with it.
ive been pulled over, no dramas, i have all necersary upgrades, so i mayaswell get somthing on paper to shut up the picky cops
what that means is for example....i put a rotary in say a nissan micra i got 30 days to get to vic roads to get it registered or let them view the vehicle to change there database..
but they wouldnt register it with out the proper upgrades
The rules were changed when the VASS scheme was introduced 5 years or so back, basically to bring engineers certificates into line with RWC practices (ie expires after defined period if not presented to VicRoads). The certificate is 'permanent' once accepted by VicRoads and goes into their records, the owner also gets a copy (or should) from the engineer. That is: original to VicRoads and car owner also gets a copy.
Al is right, it's not legal. Doesn't matter that it has smaller capacity - quite apart from the fact that the power output is more than 10% over the standard engine's output, the Rb25DET wasn't offered as an option for the R31. You need an engineers certificate - if nothing else your insurance is invalid.
mate all i can say is what ever you do even if u live next door to this bloke dont even bother going to him. Guys to f*@#en strict.
PAul bottemly and hes in heidelberg
A really good engineer ive found to be is Archie Robertson hes in bayswater
Spot on. If you get pulled over they will ask for engineers etc and if you cant produce them you'll get a fine and i'd say have your registration cancelled. IF you've done things like upgrade brake system etc then you wont have a problem getting an engineers cert. What was said about the 30 days was also spot on. You have to produce it to vic roads for it to be vaild, after that laminate it and store it in a safe place.
Archie is alright but he picks on so much little shit, like the rear numberplate. The distance was spot on perfect and met vic roads regulations, But i still had to shave off 1mm either side of the plate so that there was a small gap between the plate and the reverse lights. I asked him what that was about considering cars off the showroom floor have those number plate plastic surround things and all he said was vic roads told him to make me do it. Too much little shit.
Is this for an engineers cert. If so you'll have to get in contact with Vic roads and get a list of engineers off them. Sanjay or something like that out of warntirna south is pritty good.
He is forgetful, and changes his mind every time he looks at your car. He's also in Glen Waverley, and will come to you. I don't have his details though.
Will charge $500 for an engineers cert. Inc. chassis and structural inspection. And braking distance and fade test.
Went thru this process when I had my R32 RB25DET
just to clear up some misconceptions, doesnt matter engine capacity, R32s even came out with Rb25DE and they said I still need a engineers.
Engineers can be real picky if they want to be as well with certain things.
Cops dont care if ur cars registered with it or not, you get the wrong copper and he knows its a conversion, thats it, I was a bit unlucky because the RB25 didnt look outta place in a R32, but in a R31 it certainly does.
I dont really see the huge point in getting it engineered anyway, theres still EPAs and defects to worry about, thats why I sold the car. As someone mentioned, for insurance purposes as well, it can be a problem.(even if you have 3rd party).
Some people choose to take the risk and run without changing anything, you most probably would get away, but theres always that chance.
but still, it being engineered dose help!
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
