today my car was getting tunned and everything was running sweet then the AFM started giving out different reading..
no im no expert so im trying to repeat what i have been told.
A faulty AFM i have been told will give a very high or low reading, well mine was going up then down then centre...?
the tunner has never seen it before in all his time remapping ECU's (which he was doing with mine)
so basically he said even a 0.1 volt can make a massive difference in the high end voltage.
anyone had this happen before, or any tips?
(we are going to try a different z32 tomorrow)
disclaimer: if i sound like i dont know what im talking about its because i dont, just relaying info.
thanks
https://www.sau.com.au/forums/topic/101253-afm-giving-different-voltages/
stock ecu has no concept of how much boost you are running.
does the afm voltage vary much at idle? if its hunting around then the afm will vary a little as it will suck in a bit more air when it tries to stall recover. is it a new z32 or 2nd hand ? do u know when it last worked ok?
it was 2nd hand, i was told the voltage varies constantly, then later in the day was sitting in centre..
i was also told that when a particular sensor was turned off via ECU tunning there was no detonation
by moving the wires about do any of the voltage readings change??
hows the car coming along??
ill have a play around with the wires tonight, cars fine apart from this..
a touch laggy
if it doesnt get fixed after trying a new AFM i quite the whole remap ECU route
nothing wrong with a remapped ECU mate, you just need the sensors to tell it the right things....but I'm not 100% sure from how you described it.
Do you have a consult cable? datascan and similar show great data on the health of all the sensors to help you track down problems.
im not sure either...
i dont have a consult cable.
last night we tested 4 z32 AFM's on a 180sx
mine and another were giving out different readings, the other 2 were practically the same.
mine was running the 180 rich
I would be checking that the AFM is getting a nice constant supply voltage.
I would check that with the airflow meter disconnected that it reads low volts <1V and sits constant until i blew through it to jump it to >2V. (Need bench power supply connected of course)
I would disconnect the harness and measure resistance/check continuity through the signal wires to the AFM. (make sure there is not bad connections or piggyback devices hidden in the system)
I would do the wiggle test over all connections.
I would subtitute a 0-5V supply through the signal wire and check with a suitable consult/scan tool, that the reading did not fluctuate on the scantool hooked to the ECU itself.
All whilst measuring the actual voltages at the ecu end with a multimeter to see what was actually going on.
Well thats what i would do, coming from an auto elec.
Sorry if none of it makes sense, but if your tuner does not do the above, he will never know or rule shit out.
Shouldn't be to hard to sus it out, if he cant take it to someone else.
will pass on the info!
thanks!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
