today my car was getting tunned and everything was running sweet then the AFM started giving out different reading..
no im no expert so im trying to repeat what i have been told.
A faulty AFM i have been told will give a very high or low reading, well mine was going up then down then centre...?
the tunner has never seen it before in all his time remapping ECU's (which he was doing with mine)
so basically he said even a 0.1 volt can make a massive difference in the high end voltage.
anyone had this happen before, or any tips?
(we are going to try a different z32 tomorrow)
disclaimer: if i sound like i dont know what im talking about its because i dont, just relaying info.
thanks
https://www.sau.com.au/forums/topic/101253-afm-giving-different-voltages/
stock ecu has no concept of how much boost you are running.
does the afm voltage vary much at idle? if its hunting around then the afm will vary a little as it will suck in a bit more air when it tries to stall recover. is it a new z32 or 2nd hand ? do u know when it last worked ok?
it was 2nd hand, i was told the voltage varies constantly, then later in the day was sitting in centre..
i was also told that when a particular sensor was turned off via ECU tunning there was no detonation
by moving the wires about do any of the voltage readings change??
hows the car coming along??
ill have a play around with the wires tonight, cars fine apart from this..
a touch laggy
if it doesnt get fixed after trying a new AFM i quite the whole remap ECU route
nothing wrong with a remapped ECU mate, you just need the sensors to tell it the right things....but I'm not 100% sure from how you described it.
Do you have a consult cable? datascan and similar show great data on the health of all the sensors to help you track down problems.
im not sure either...
i dont have a consult cable.
last night we tested 4 z32 AFM's on a 180sx
mine and another were giving out different readings, the other 2 were practically the same.
mine was running the 180 rich
I would be checking that the AFM is getting a nice constant supply voltage.
I would check that with the airflow meter disconnected that it reads low volts <1V and sits constant until i blew through it to jump it to >2V. (Need bench power supply connected of course)
I would disconnect the harness and measure resistance/check continuity through the signal wires to the AFM. (make sure there is not bad connections or piggyback devices hidden in the system)
I would do the wiggle test over all connections.
I would subtitute a 0-5V supply through the signal wire and check with a suitable consult/scan tool, that the reading did not fluctuate on the scantool hooked to the ECU itself.
All whilst measuring the actual voltages at the ecu end with a multimeter to see what was actually going on.
Well thats what i would do, coming from an auto elec.
Sorry if none of it makes sense, but if your tuner does not do the above, he will never know or rule shit out.
Shouldn't be to hard to sus it out, if he cant take it to someone else.
will pass on the info!
thanks!
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
