What is it about the stock turbo's on RB20/25's that make the induction sound so loud.
even with the stock air box in.?
I'm sick of it already.
Is it something with the design in the wheels or maybe the compressor inlet?
my SR was never this loud.
neither was the 4G63.
and no, there is no leaks or gasket issues.
it's just the standard skyline turbo sucking sound.
https://www.sau.com.au/forums/topic/101348-rb-turbos-induction-noise/
The VG30DEt turbo is much quieter... No loud whooshing as it comes on boost yet it runs the same core (comp and turbine wheels) as the rb20det turbo only larger turbine and compressor housing. The other difference is the compressor housing snout is smooth in to the compressor, the rb20 and rb25 turbo's have a slight step in front of the compressor wheel. I assume this causes a little turbulence causing the loud whoosh noise as its building boost. :unsure:
fit an airbox with a panel filter, that will shut it up
This is true,just make sure the sponge stuff on the lid is on if you want to reduce induction noise take it off and it increases the sound surprisingly.
GTST,
The VG30DET turbo and the Rb25 turbo run the same sized comp cover, the only differece once again being the vg30 is smooth where as the rb25 has a step up. The Rb25 turbo is a noisy bugger like the rb20 turbo. I am 99% sure its this little step in front of the comp wheel that causes the noise.
Do you have the stock BOV fitted?
For some reason on both mine and a mates GTS-T, when we had the Stock BOV working it makes a much different and louder aray of sounds when its spooling.
When the aftermarket item went back on and the stock one was blocked off, less sound during spool up...
I run the stock bov.
The VG30DET turbo is so much damn quieter than the rb20 and rb25 turbo's. It HAs to be the step in the turbo's intake. :unsure:
If you block off the little bleed hole in the stock bov it also makes spool rather quiet, I experienced roughly part throttle acceleration through the hills so I removed screw I used to block the bov's bleed hole.
I blocked off the bleed hole on my last skyline.
but like you said, it's not a smooth transition between on and off throttle or part throttle.
so I'm leaving this one as is.
I'll have to put up with it for a while as is.
once I settle in to QLD, and everything is back to normal and bank account is a little beefier, THEN, I can build the RB30 that I want and stick the gt30 to the side of it.
I hate having it all planned out and no funds to make it happen.
NOTE TO MEN: Don't pay for your own wedding.
oh and don't have your UNINSURED car stolen.
oh oh.. and don't do all of the above when paying a MORTGAGE.
Lets hope 2006 brings better luck than 2005.
:unsure:
the only new part to this engine build will be bearings, turbo, sump adapter, idler pulleys and timing belt and ECU
bottom end will be stock.
just checked and tested.
and I will use the pistons it came with.
head will be stock with second hand 25det springs to be sure.
oil pump, second hand.
injectors I will get GTR ones.
B
U
D
G
E
T
We'll see how long the gts4 box holds up.
and I will only have it tuned with 14-17psi... don't want to really go over 1bar.
what ever power that yields is cool with me.
yep.. new rings, bearings, and new gaskets.
all parts will be OEM nissan/holden bits.
I just want it to be reliable.
so I will replace parts that are required.
nothing forged though.
I don't think it will be required for my needs.
I should also add oil cooler kit to my list of NEW things to buy.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
