What is it about the stock turbo's on RB20/25's that make the induction sound so loud.
even with the stock air box in.?
I'm sick of it already.
Is it something with the design in the wheels or maybe the compressor inlet?
my SR was never this loud.
neither was the 4G63.
and no, there is no leaks or gasket issues.
it's just the standard skyline turbo sucking sound.
https://www.sau.com.au/forums/topic/101348-rb-turbos-induction-noise/
The VG30DEt turbo is much quieter... No loud whooshing as it comes on boost yet it runs the same core (comp and turbine wheels) as the rb20det turbo only larger turbine and compressor housing. The other difference is the compressor housing snout is smooth in to the compressor, the rb20 and rb25 turbo's have a slight step in front of the compressor wheel. I assume this causes a little turbulence causing the loud whoosh noise as its building boost. :unsure:
fit an airbox with a panel filter, that will shut it up
This is true,just make sure the sponge stuff on the lid is on if you want to reduce induction noise take it off and it increases the sound surprisingly.
GTST,
The VG30DET turbo and the Rb25 turbo run the same sized comp cover, the only differece once again being the vg30 is smooth where as the rb25 has a step up. The Rb25 turbo is a noisy bugger like the rb20 turbo. I am 99% sure its this little step in front of the comp wheel that causes the noise.
Do you have the stock BOV fitted?
For some reason on both mine and a mates GTS-T, when we had the Stock BOV working it makes a much different and louder aray of sounds when its spooling.
When the aftermarket item went back on and the stock one was blocked off, less sound during spool up...
I run the stock bov.
The VG30DET turbo is so much damn quieter than the rb20 and rb25 turbo's. It HAs to be the step in the turbo's intake. :unsure:
If you block off the little bleed hole in the stock bov it also makes spool rather quiet, I experienced roughly part throttle acceleration through the hills so I removed screw I used to block the bov's bleed hole.
I blocked off the bleed hole on my last skyline.
but like you said, it's not a smooth transition between on and off throttle or part throttle.
so I'm leaving this one as is.
I'll have to put up with it for a while as is.
once I settle in to QLD, and everything is back to normal and bank account is a little beefier, THEN, I can build the RB30 that I want and stick the gt30 to the side of it.
I hate having it all planned out and no funds to make it happen.
NOTE TO MEN: Don't pay for your own wedding.
oh and don't have your UNINSURED car stolen.
oh oh.. and don't do all of the above when paying a MORTGAGE.
Lets hope 2006 brings better luck than 2005.
:unsure:
the only new part to this engine build will be bearings, turbo, sump adapter, idler pulleys and timing belt and ECU
bottom end will be stock.
just checked and tested.
and I will use the pistons it came with.
head will be stock with second hand 25det springs to be sure.
oil pump, second hand.
injectors I will get GTR ones.
B
U
D
G
E
T
We'll see how long the gts4 box holds up.
and I will only have it tuned with 14-17psi... don't want to really go over 1bar.
what ever power that yields is cool with me.
yep.. new rings, bearings, and new gaskets.
all parts will be OEM nissan/holden bits.
I just want it to be reliable.
so I will replace parts that are required.
nothing forged though.
I don't think it will be required for my needs.
I should also add oil cooler kit to my list of NEW things to buy.
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
